Results 1 to 6 of 6
- Jan 2015
- 22
March 21st, 2015 01:29 AM #1Hello mga sirs! Sentra B13, M/T. Baka meron sa inyo sirs may idea kung ano culprit ng problem ng ride ko. After ko magpakabit ng fog lights, bigla akong namamatayan. Kapag nagcrucruise, tapos nilagay sa neutral, nagdidive pababa yung RPM to the point na namamatay engine. Kapag nakaidle naman yung auto, minsan nagflufluctuate RPM, taas-baba, mamatay na minsan unless tapakan clutch. TB, MAF, IACV cleaned just 2 months ago.
Sa wiring kaya problem or tune-up lang kailangan or other factors? Thanks mga sirs!
- Mar 2014
- 901
March 21st, 2015 09:30 AM #2Everytime ba you use or turn on your foglights?
Sent from my Starmobile UP+ using Tapatalk
- Aug 2014
- 391
March 21st, 2015 08:21 PM #3try to disconnect the newly connected fog lights, then start engine normally. Baka merong short circuit...
March 23rd, 2015 09:36 AM #4
tama si aloshin.
most probably incorrect grounding or short circuit.
tama si aloshin.
- Oct 2009
- 2,271
March 23rd, 2015 03:25 PM #5baka namali ng kuha ng supply ng relay.
sa halip na sa parkligth eh baka sa ibang lines naka kuha,
simple lang naman yan at baka dati ng may problema tsikot mo..
bunutin mo lang ang relay na naka lagay sa foglamps saka mo test drive kung mag luluko pa.pag nawala problema ibig sabihin may short circuit.
pero pag ganun parin aba wag kang mag hinala sa foglamps mo..
cause ng pag bagsak ng rpm madumi throttle body.baradong air filter.wala sa timing spark plug.high tension wire.
pero sa akin pag ganyan na kadalasan sa throttle body lang nililinis ko,& air filter, saka kauntin timing.
- Jan 2015
- 22
March 24th, 2015 08:50 AM #6Maraming salamat sa inputs sirs! Okay na yung ride ko. Dinisconnect ko connections sa terminal, tapos tumino na, tapos kabit ulit. Hindi na bumalik fluctuating RPM. Sabi ng mekaniko malamang nanibago lang ang system sa bagong demand ng power from fog lights.
Discover the ultimate in relaxed romance with the best casual dating platform! Authentic Ladies ...
Exemplary Сasual Dating - Verified Damsels
