Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Mar 2017
    Madalas nyo bang makita ang ganitong klaseng corrosion?
    Hindi lang sa Amaron nagkakaroon ng ganitong corrosion kahit ano pang brand nagkakaroon ng ganito.
    Kung hindi magstart ang oto mo, tingnan mo muna kung may ganito ang terminal ng battery mo. Brush lang ang katapat nyan at tubig, brushin mo lng hanggang lumambot ang umido at mawala or maubos. Nakakabawas ng contact ang corrosion minsan wala talagang contact kapag sobrang kapal na. At minsan kelangan idismantle ang batt terminal para maalis ang corrosion sa palibot ng battery post.
    Sana makatulong ito ng konti sa inyo guys.
    Sent from my A37f using Tsikot Forums mobile app
    Oct 2009
    nagkakaroon ng ganyan pag maluwag na ung battery terminal at madalas nababasa ng tubig..kaya dapat palaging mahigpit ang batt terminal.
    May 2009
    This should not happen in the first place on your battery if it is maintenance free. If it does return the battery to your dealer kasi may leak yan and it will definitely drain your battery liquid and destroy your battery early.
    Quote Originally Posted by Admer and 3J View Post
    this shouldn't happen.
    you have a defective battery. cracked battery cover, etc.
    but to convince the dealer that the battery came like that... that you did not cause it by connecting the metal terminal using a bad maneuver... good luck.
    Jan 2008
    Experience ko lang.. sa auv namin dati na panget electrical wiring ganyan lagi battery.. nag uumido.. nung ma re-wire yung auv namin nawala yan kahit na de tubig yung battery.. so duda ko may parasitic load yan "grounded" sa common terms or may loose somewhere kaya ganyan
    Aug 2008
    Have you checked the Electricals on the vehicle? I had one case where some chemicals coke up just outside the battery fill holes after 1 year of normal operation (and appearance). but on mine, it was accompanied by Low-Battery so I checked the terminals and was having almost 0 resistance between + and - terminals which indicate a short somewhere. removed the fuses one by one, culprit was the door lamp - the red light on the driver/passanger door. Removed the fuse and Battery would function normally afterwards.
    Dec 2007
    It happens to my previous vehicles. A friend of mine told me that sometimes different materials used on battery terminals and wire termination can have the effect. When I switched to lead terminals, it never happened to me anymore.
    HTH
    Sent from my ASUS_Z012D using Tapatalk
    Quote Originally Posted by Nelson de Leon View Post
    HTH
    lead does not react with battery acid.
    many years ago, lead was the metal of choice for battery cable terminal clamp metal. at that time kasi, battery technology was still not as good as today's, and neither was voltage regulator science. every battery would cause the non-lead terminal clamps to develop white deposits and loosen.
    lead clamps do not do this. but because lead was soft, it deformed with time and got loose, and the resulting electrical connections got weak. we had to regularly service them terminals.
    in response, manufacturers introduced the harder metal alloys like brass, copper, and others, which would oxidize naman, necessitating regular maintenance, cleaning and tightening.
    it is only now, with better battery sealing, that non-lead clamps can last longer, without regular maintenance.
    notice that even today, all our auto batteries still use lead for their battery terminal posts.
    Oct 2004
    Just make sure your battery terminal clamps are tight.
    ...and put some silicon grease (grease ha, not sealant).
    Feb 2014
    Quote Originally Posted by EssB View Post
    silicone not silicon
    pero pwede rin general-purpose grease
    not enough people are doing this. but it's so easy
    Oct 2004
    Oo nga, kinulang ako ng 'e'. Hehe!
    Silicone grease is most recommended kasi di matutunaw at kakalat basta dahil sa init ng engine bay, unlike petroleum based grease.
    Sep 2017
    ok na battery chong?
    May 2020
    Ano nga palang mas recent update tungkol sa Amaron Battery? Wilding sila sa FB, nakaka-interest dahil dami din kumukuha
    Apr 2009
    Replaced the stock batt of my CR-V with 65B25LS (1SNF size).
    Attachment 39356
    Sent from my XQ-AS72 using Tapatalk
    Feb 2019
    Is it true that when your car is often park outside with sunlight it will shorten the life of your battery?
    Jan 2009
    High temperature degrades your battery. The heat produced by sunlight is lower than the heat generated by the engine. If your hood has insulation, no need to worry about the heat due to sunlight.
    nope.
    but when we were young, we would make bilad our weak eveready dry cells in the sun, to eke out the last ergs from them.
    Jan 2008
    not true sir.. although heat from the engine will have some effect on the battery.
    also cold weather can weaken the battery charge.. hence you may experience hard starts in the morning
    Apr 2009
    Agree. We dont have covered parking in my workplace, so 5 days a week babad sa araw tsikot ko. Well, rest day pag habagat [emoji1787]
    But still, my average battery life is around 2yrs.
    Jan 2009
    Battery life would depend on use. I am averaging 4 to 5 years use, but only 45 to 1 hour cumulative use daily and occasional long trips. When I sense the battery is weakening, I do long trip travel, to fully charge the battery.
Amaron Battery users
