Results 1 to 9 of 9
    Mar 2003
    guys wat do i use to clean the mast of my power antenna? may black, sticky gunk na kac e, also after cleaning, wats a gud lubricant for it? tnx
    just wipe it repeatedly with a clean cloth until the dirt is gone. lubricating it will just attract more dirt & grime
    Mar 2003
    momoyster sa pajero mo ba yung antenna? ganyan nagsimula yung sa antenna ko di sumsagad hanggang isang araw di na talaga gumana last wk 99 model din. nabali yung white plastic sa loob ng antenna, pa adjust mo na or wag gamitin. i think meron napepwersa sa loob pag di sumasagad.
    The black is grime...originally white grasa yun. Ang mapupuwersa ay yung white plastic (which is actually a gear). Dahil hindi iyun bumababa ng todo, the gear eventually ay mapupudpod. Thus puedeng maputol or di na gumana.
    Have it cleaned and regreased sa mga marunong magkalas or iDIY mo...if you want to dare it.
    Jan 1970
    Try WD40 :-)
    there is a special grease for use on electrical/electronics. generic name is silicone grease electronic grade. just clean the antennae with a degreaser to get rid of the grime then apply a thin layaer of grease. do this every month and guaranteed di magka-problema yan. it all boils down to regular maintenance.
    gear yung nasira sakin. pinapatay ko nalang yung power supply sa power antenna. yun di na sya umaakyat tlga.
    kadalasan, cd naman ako sa auto eh :D
    PROMDIBOY:: Korek! Thats the same thing which happend to my Paje's antenna. What i did was have the banawe boys replace the plastic core (yung white na may ngipin) with a brand new one, Php700.
    Mar 2003
    promdiboy, d sa pajero e, yung sa vr ko ang nagluko. anyway, tnx 4 all ur replies everybody. i jst used an old toothbrush 2 clean d grime of d mast. ok na sya uli ngayon. =)
my power antenna somtimes doesnt fully retract
