Ahhh...With no misfire, wires are still conducting well. No soldering needed. You just need to properly reinsulate them.
Step 1. Unplug the connector(BLUE) for the ignition coil.
Step 2. Disengage/Release each pin of each affected wire(RED) individually from the coil connector.
Step 3. Tape the chafed wire individually.
Step 4. Sleeve a shrink wrap over each bundle of individually taped wires. This will add protection & restore the OE look.
That's pretty much it.
Call PeligRacing +639152894590 if no dealership will do this repair for you. I have seen this procedure done w/o issues.
Thank you Sir, already called PeligRacing. Hoping to have a positive feedback from them. Thanks!
