Results 1 to 3 of 3
May 4th, 2011 01:48 PM #1
mga sir need some inputs i having a problem regarding with my car civic ph15 carb may times kasi na habang nasa byahe ka biglang mamatay yung engine.cause ng pag stall ng engine is nawawala yung supply ng kuryente kailangan ko pa tumabi at huminto para ma start ko uli.pero one click naman need lang huminto pa start sa susian pag yung jumpstart(kadjot) ayaw.and napansin ko din po na parang maluwag na yung key sa susian.salamat...
May 4th, 2011 05:06 PM #2
ipa check mo yung ignition switch agad, delikado yan sa hiway pag namatayan ka ng engine...
common problem ng honda ang ignition switch, di kasi masyo sealed kaya kinakalawang yung maliit na spring at napuputol pag nagka moist. sometimes nagkakaroon naman ng tutong (dirt) yung contacts, nag iinit kasi lalo na pag medyo mahina na ang contact niya.
- Dec 2006
- 234
May 8th, 2011 04:59 PM #3Check mo to bro:
http://www.hondalac.com/service/Bulletins/x02-031e.pdf
Safety Recall: Ignition Switch
(Supersedes 02-031, dated September 2002)
BACKGROUND
Electrical contacts in the ignition switch can wear
prematurely due to high electrical current passing
through the switch. Worn-out ignition contacts could
cause the engine to stall without warning. Although the
engine will restart in most cases, a vehicle that stalls
while driving increases the risk of a crash.
VEHICLES AFFECTED
• 1997–99 Accord (L4)
• 1998–99 Accord (L4 and V6)
• 1998–99 Civic
• 1997–99 CR-V
• 1997–99 Odyssey
• 1997–99 Prelude
Not every vehicle in the years and models listed
above is affected by this campaign. Before
beginning work, verify that the vehicle is eligible by
checking your campaign responsibility report.
Traffic!
