Results 1 to 5 of 5
    Oct 2004
    Sir tanong ko lng, bakit po umilaw yon "malfunction indicator lamp" sa Honda city na model 1998. Umilaw po ito habang ako ay tumatakbo, tapos nong na pansin ko umilaw tumabi ako at pinatay ko makina, tapos pinaandar ko uli. Hindi na uli umilaw. Ano kaya ibig sabihin ito? Salamat.
    pag umilaw ang MIL (malfunction indicator lamp) may trouble na na -detect ang ECM mo
    kailangan scan test and check for codes stored
    magagawa yan ng auto shop na may scanner
    kung medyo deep ang trouble hanap ka ng shop na specialized sa electonic fuel injection systems
    Nov 2003
    no need for a scanner. just pull the 3 pin plug and short it. then read the number of blinks sa dash and compare it to a list of codes.
    May 2007
    The malfunction indicator lamp of my honda city 2004 model lit up when I passed through a deep flood. When i had it checked in the casa, they told me that the oxygen sensor was damaged and had to be replaced. I spent 13k for it.
    Nov 2003
    2002 models and up locally will use the obd2 port and cannot have the codes scanned manually.
Malfunction indicator lamp
