Results 1 to 20 of 25
    Quote Originally Posted by microserf
    hi, i had the same problem, na discharge ang Motolite Enduro ko, after almost 2 years. Where are the other recharging stations? how can one easily check for the "lifespan" of a car battery? pls advise thanks
    Ok na yan, 2 years na naman bili ka na bago
    Nov 2007
    hey, mine is 4yrs and counting (motolite) di pa namna pumalya, pero dapat na bang palitan?
    Quote Originally Posted by jansky
    Kung A/T yes, pag manual sagarin mo na hanggan mamatayan ka na lang.
    Jul 2010
    kaya pa iyan either by bringing the battery to a battery dealership to have it recharge or push-starting the car.
    Nov 2007
    kwento ko pala biglang namatay nung nag slow down ako .. need to push the car to start.. nagpaparamdam na ata ah (december 2nd week)
    after new year - pagka park then after an hour ayaw mag crank pero may ilaw sa dashboard.. ginawa ko hinigpitan ko battery biglang one click
    its time na ata .. or there is something wrong?
    Quote Originally Posted by jansky View Post
    Have it checked muna, ilang year/months na ba?
    Pero sign na yan bro. Ganyan din sa akin eh last December.
    Nov 2007
    4yrs and counting heheheh
    discharged battery? we used to start the car by push-starting it. if you have a battery charger, fast-charging for 5-10 minutes may be enough to have the car started. there is no need to charge the battery afterward. in modern cars, 30 minutes of normal daytime use afterwards, will adequately charge the battery. if the battery discharges again for no apparent reason, have the battery and the charging system checked.
    nowadays, i use maintenance-free batteries. in our experience, we never had to maintain them until they naturally die after 24 months or more. also, there is no need to protect the overhead metal..
maintenance free batt question
