Results 1 to 7 of 7
    Dec 2007
    Sa mga naka subok na...
    Given:
    - Car is parked after being driven for about 15 mins (engine is not running). Yung tipong magsusundo ka tapos maaga ka naka rating.
    - Battery is 3SM, 8 months old, good condition.
    - Alternator is stock 60Amps ata yun and in good condition.
    - Charging is good, in-dash voltmeter reads around 13+V most of the time.
    - Audio is 6 speakers (2 front tweeters + 2 front + 2 rear) + amps + 10" subs and volume is ... say nearly halfway.
    Question:
    Mga ilang minutes safe mag sounds na naka off ang engine?
    I appreciate your shared thoughts and experiences in advance.
    Feb 2009
    Quote Originally Posted by wham_10mbps View Post
    Given:
    Question:
    depends on two factors:
    1-ampere/hour rating of the battery and its condition
    2-how many amps is the load (use an ammeter to measure average current whilst your audio entertainment system is drawing)
    Dec 2007
    I appreciate the scientific response sir jick.cejoco. I am sure it is the right approach so leme try to get a specialist who could do it for me. or could there be some spec printed on the battery itself that would tell me such. If there is, how do we read it? Unfortunately I do not have an ammeter and my VOM on reads a max of 10A w/c could get fried.
    Oct 2009
    Battery has a rating that is called Reserve Capacity, usually a 3smf battery has over 120 minutes of capacity drawing 25-amp, until the voltage drop to 10.5V, but a here is a rough estimate of battery charge left 12.6V full, 12.4 3/4, 12.2 1/2, 12.1 1/4. for a safe start-worry try not going below 1/2 charge or 12.2, for me, my with 2-12inch 250W subwoofer car full blast i don't go over 10-15min on a 2smf battery.
    Feb 2009
    Given:
    Question:
    just a thought:
    how about purchasing a good bose headset and an ipod. then when the ipod is low on charge, plug it in to the cigarette lighter outlet to recharge
    Dec 2007
    Costly but it makes sense Jick.
    Paul - Gotcha! I appreciate going straight to the point. Thanks for sharing your actual experience/practice as well.
    just a thought:
How long would a battery get discharged after a prolonged use listening to music?
