Results 1 to 2 of 2
    Jun 2006
    Tanong ko lang mga sir kung magkano surplus distributor para sa ga16de?
    yung brand new kasi 30K daw e.
    thanks!
    May 2007
    With that much money, better have that distributor rebuild.Usually, distributor last a lifetime of the car. Most common problem with distributor are bad bearing allowing the shaft to wobble. In addition, replace the distributor only if NOT rebuildable like housing is cracked and the shaft is bent it may be time to purchase another replacement.
Magkano Distributor ngayon?
