Results 1 to 12 of 12
    Mar 2018
    Hello po mga sirs
    HOPE you can enlighten me
    Car NISSAN sentra super saloon
    Ayaw po mag start ng kotse kahit redondo wala. May sinundot po yung di ko lam if legit na mekaniko sa makina nag start naman sya parang may jinamper ata gamit flat screw driver.
    Ayun po dun sa mekaniko[not sure if legit ngang mekaniko] drain daw po battery ko ang sanhi daw eh pag on palang ng koste umiikot na agad yung fan ng rad. Naka rekta daw. Kaya pag pihit ng susi para i istart yung makina eh wala naraw sapat na koryente.
    Tanong ko po ay nakakadrain ba ng malaki ang rad fan pag on palang ng kotse? O sadyang mahina na battery?
    Balak ko kasi eh tangalin sa rekta at matic nalang iikot ang fan oag mainit na. Kaya lang kinakabahan ako pano ko malalaman na iikot nga fan pag mainit na ang kotse.
    Hope you can help me with this guys
    Sent from my ASUS_X00DDA using Tapatalk
    Quote Originally Posted by Baltz View Post
    Hello po mga sirs
    that should be easy.
    bring the car to an auto aircon shop, and tell them to put the aux fan connections back to factory spec.
    dapat naman talaga, na hindi rekta.
    Feb 2009
    Hello po mga sirs
    Things you can do:
    Turn headlights on, with them in, attempt to crank the engine. If the lights dim, the battery may need to be rechaged. Try again with a charged battery.
    Check your battery connections for corrosion and loosesness.
    Check your battery voltage at rest. Check voltage while cranking.
    Try doing the confirmation tests before going to a potential hungry crocodile with its jaws open.
    Mar 2018
    Things you can do:
    Yes boss I followed your advice nag didim yung head lights nung na pa crank ko one time, and mababa na daw voltage according dun sa nag bebenta ng battery [emoji20] [emoji20] [emoji20] , medyo kinakabaham ako kasi sabi nila kelangan i replace na yung battery, baka lang kasi may iba pang sira pag bumili ako battery.
    Thanks boss for the advive
    Feb 2009
    Recharge battery and retest/reevaluate
    Mar 2018
    Thanks sir , will surely do that
    May after market alarm ba yan? Ganyan nangyari sa oto ko. Dahil sa alarm.
    Bili ka ng thermostat and thermoswitch para balik sa tamang specs kotse mo. At malamang madami pang shortcut na ginawa dyan. Ipatingin mo sa matinong mekaniko.
    Mar 2018
    Quote Originally Posted by robot.sonic View Post
    Hi sir
    Wala pong alarm yung otto, naka rekta lang yung fan. Yung ang problem ko, newbie and first car ko lang to. Di ko alam kung san dito samin may trusted mechanic[emoji20] [emoji20] [emoji20]
    Imus cavite
    Hi sir
    Imus cavite
    Kung may facebook group na specific sa oto mo,sali ka doon. baka makahanap ka ng recommended mechanic.
    Yung trusted ko sa bacoor pa pero dinadayo ko from QC para sa mga repairs.
    Mar 2018
    Hi sir
    Sadly walang groups yung otto ko sa fb[emoji20] [emoji20] [emoji20] , pede ko ba sir malaman yung talyer na dinadayo nyo sa bacoor?
    Hi sir
    PM ko sayo Sir.
    Mar 2018
    Hi mga sir
    Salamat sa mga advice nyo, it turns out na susian ang may problema ayun pina ayos ko na, thanks again guys
Rad fan, battery CONFUSED
