Results 1 to 10 of 12
- Mar 2018
- 66
March 25th, 2018 09:48 PM #1Hello po mga sirs
HOPE you can enlighten me
Car NISSAN sentra super saloon
Ayaw po mag start ng kotse kahit redondo wala. May sinundot po yung di ko lam if legit na mekaniko sa makina nag start naman sya parang may jinamper ata gamit flat screw driver.
Ayun po dun sa mekaniko[not sure if legit ngang mekaniko] drain daw po battery ko ang sanhi daw eh pag on palang ng koste umiikot na agad yung fan ng rad. Naka rekta daw. Kaya pag pihit ng susi para i istart yung makina eh wala naraw sapat na koryente.
Tanong ko po ay nakakadrain ba ng malaki ang rad fan pag on palang ng kotse? O sadyang mahina na battery?
Balak ko kasi eh tangalin sa rekta at matic nalang iikot ang fan oag mainit na. Kaya lang kinakabahan ako pano ko malalaman na iikot nga fan pag mainit na ang kotse.
Hope you can help me with this guys
Sent from my ASUS_X00DDA using Tapatalk
- 52,700
March 25th, 2018 11:08 PM #2
March 26th, 2018 06:19 AM #3
Things you can do:
Turn headlights on, with them in, attempt to crank the engine. If the lights dim, the battery may need to be rechaged. Try again with a charged battery.
Check your battery connections for corrosion and loosesness.
Check your battery voltage at rest. Check voltage while cranking.
Try doing the confirmation tests before going to a potential hungry crocodile with its jaws open.
March 26th, 2018 09:07 AM #4
- Mar 2018
- 66
March 26th, 2018 10:53 AM #5Yes boss I followed your advice nag didim yung head lights nung na pa crank ko one time, and mababa na daw voltage according dun sa nag bebenta ng battery , medyo kinakabaham ako kasi sabi nila kelangan i replace na yung battery, baka lang kasi may iba pang sira pag bumili ako battery.
Thanks boss for the advive
- Mar 2018
- 66
March 26th, 2018 10:55 AM #6
March 26th, 2018 11:43 AM #8
- Mar 2018
- 66
March 27th, 2018 10:33 AM #9
- Mar 2018
- 66
March 27th, 2018 10:34 AM #10
