Results 1 to 10 of 11
- Dec 2008
- 22
December 20th, 2008 03:32 PM #1i have a problem with my headlight, halos di ko kasi makita ang mga humps sa ilaw ko.Ngayon balak ko palagyan ng fog lights, malakas ba yun sa battery? Dapat ba hiwalay ang switch? Tnx
December 20th, 2008 03:37 PM #2
sir hindi naman malakas.. maganda nakahiwalay yung switch.. para kung gusto mo nakaopen or hindi yung fog light po sir..
- Dec 2008
- 22
December 21st, 2008 06:59 AM #4
baka naman hindi lang naka-focus? pwede din upgrade mo bulbs or wattage para di ka na maglagay ng fog lights.
December 26th, 2008 02:23 AM #5
upgrade wiring and direct relay muna, then use osram nighbreaker or philips xtreme. same wattage but 80-90% more light. clean the headlights and check if it needs re-aiming...
January 5th, 2009 12:16 PM #6
makikisakay na rin ako sa topic. problem ko is my left headlight mahina as in halos walang light compared to to right. i think meron nagloose or grounded, feel ko lang(not sure) kc sometimes maliwanag naman.
ano or saan kaya problem? TIA
January 5th, 2009 12:20 PM #7
January 7th, 2009 08:51 PM #8
thanks bro. got the problem solved after checking all connections. as it turned out, the 10A fuse terminals had oxidized thus the poor contact. initially, remoed the oxidation and it worked. had replaced it with a new fuse just to make sure.
now i have another puzzle, this was even before the headlight problem came about. at nomral or during day time, the clock & shift indicator lights are bright. (btw, my car is a gen 1 crv at) but once the park light are turned on, the clock & shift indicator brightness goes down by atleast 50%. my feel is that this problem cause to reduce the instrumention light to deem as well.
any input will be highly appreciated.TIA
January 13th, 2009 08:25 AM #9
It is normal for the clock and indicator lights to lose some degree of brightness when the park lights are turned on. A 50% loss of intensity may be a bit on the high side, so have your wirings checked for any loose grounding or connection.
7303:soda:
January 18th, 2009 10:52 AM #10
ur right, that's the same reply i got from mechanic. sabi nya normal daw yun kc walang relays. i was wondering kung 2SM battery ang ilagay ko, would that help to brighten up things? kc right now, 1SM lang & that's the original requirement.
Hmmm.... Kailangan na ng aircon service niyan innova mo. I have a blackish red innova. Bilad sa...
