Results 1 to 4 of 4
- Dec 2012
- 3
December 31st, 2012 01:08 PM #1
December 31st, 2012 06:36 PM #2
You're probably very close. They're usually together in a connector. How did you look for your wires? On the main door lock, the footwell or direct to the ecu? Using what tools?
- Jul 2010
- 570
January 8th, 2013 10:11 AM #3Swerte mo. The other day ko lang natutunan details ng central door lock wiring ng kotse. Madalas kasi ako masiraan ng actuator ( laging bungi ang mga gears ).
Lock and unlock switch kinabitan ng Brown at White. Kung ayaw mo gumamit ng 2 push button switch. Pwede rin 1 push button switch gamitin.
Connect mo Brown at White wire sa 2 terminal ng 1 pc.Push Button Switch. Every time mag push ka ng button ay mag toggle ang locking at unlocking ng door lock actuator.
Ano pala brand ng Door Lock Actuator mo? Sana hindi HT-610. Baka masunugan ka ng wire ng kotse.
Meron na ko na-post about HT-610 door lock controller dito sa tsikot.
http://tsikot.com/forums/car-securit...0/#post2068261
February 2nd, 2013 01:18 AM #4
bro, maaring late na to, heres how.
kailangan mo check muna kung alin sa COM2/NO2 at COM1/NO1 ang lock o unlock ng alarm.
pag na determine muna ito, ikabit mo ito sa switch ng central door lock.
maaring ganito ang connection depende sa resulta ng test mo sa alarm.
Combination 1
COM1 - GROUND and COM2 - GROUND
NO1 - BROWN and NO2 - WHITE
Combination 2
NO1 - WHITE and NO2 - BROWN
