Page 10 of 32 FirstFirst ... 6789101112131420 ... LastLast
Results 181 to 200 of 629
    #181
    doc, im thinking of adding an aux fan in the right side of the pajero's grill. this is where the tranny cooler is located. left side is the stock a/c aux fan. any suggestions for the brand of fan to use? yung malakas sana hehe to aid the cooling of the rad din during the middle of the day.
    #182
    I use the Php600.00 Sanden Taiwan fans since they are compact and when they break down in 4 to 5 years, you can just buy a new one. Malakas naman siya. Ginagawa siyang electric fan ng ibang jeepney drivers. hehe.
    #183
    cleaned power window motor, replaced gauge clsuter bulbs to LED, replaced temp cluster busted bulbs, installed additional aux fan, installed antenna.
    everything done c/o Jemson. except LED and antenna.
    #184
    I think it is roy that does the led gauge mod.
    Jun 2010
    #185
    *crazyboy san mo nabili mga led bulbs for your gauge cluster?
    #186
    Doc, si roy before nagkabit ng projector headlights ko. hehe as for my gauge cluster, T10 LED bulb replacements lang. direct replacement of my existing T10 bulbs.
    yung ginagawa siguro ni roy is LED retrofit na talaga?
    Quote Originally Posted by raycon_24 View Post
    sir, sa ebay ko lang nabili yan. pero marami naman sa banawe yan. though, SMD5050 LED kasi yung akin, hindi ko lang sure kung ganun din ba yung mga nasa banawe. mas maliwanag kasi yung SMD5050.
    #187
    I have a photo of the commonly used bulb they use for the clusters, upload ko later. They use other types also depending on the application.
    Direct fit lang po. No mods required other than the bulb.
    Edit. Its the same bulb as in the picture above. Though pag pwede, they use the variant with more leds po.
    #188
    doc, please do update. so that we will know the names of the bulb sizes.
    #189
    Size lang ang pwede. Di ko alam name. Hehe. Meron din shorter than the one youposted. Sa warning lamp ata ginagamit. Basta madami sila nakukunan dun kapag office hours. Hehe
    #190
    sige Doc, pa post na lang din for future reference hehe
    Mar 2012
    #191
    *CB san nyo nabili yung aux fan? and is that automatic or may manual switch ? parang ok yung idea lalo na ngayong sobrang init talaga.
    Sayang, papatanong ko sana din kung kaya ni jemson mag diy ng power window switch natin. Diy sana na 'auto up' aside from 'auto down' lang.
    #192
    Dalhin niyo po yung mga online diy instructions para mas sure. Ganun ginawa namin sa boost gauge at egr block. Hehe
    #193
    Photo of the bulb used in the LED gauge mod:
    I'm also starting a separate thread on the LED Gauge Mod at:
    http://tsikot.com/forums/car-lights-...1/#post1909723
    Aug 2011
    #194
    LED - Sir kaya po ba niya yung sa steering wheel controls ng Fortuner? Madilim na kasi. Pati po yung mga aircon switch ng sedan ko?
    #195
    Maigi siguro si Jemson na matanong sa steering wheel. Just call him up on his number on page 1. Monday to Sunday 10am to 5pm is their usual office hours.
    Sa Patrol, maliit bulbs ng a/c panel and mahirap mag-hanap ng LED for that size. Pero meron naman since some customers do bring in their own bulbs. Sa Suzuki, same lang ng gauges ang yung bulb ng a/c control as far as I remember.
    Chances are maliit din bulbs ng Fortuner since each button is individually lit.
    #196
    Quote Originally Posted by Zipspeed View Post
    sir, hindi ko alam e. si jemson na gumawa lahat. the good thing is, the under hood temp is now cooler.
    doc, T10 nga yan hehe yan din gamit sa park light and plate lights ng ibang sasakyan.
    #197
    hahanapin ko ito bukas..pa check ko headlight ko high beam lang meron then ang busina kapag tumaas ang temp nawawala..tsk
    Doc from qc circle I will turn right to banawe?leftside or rightside po sila banda?between anong streets po ba sila?TIA
    #198
    Quote Originally Posted by mazdab22 View Post
    Sir pareho tayo ng pinanggagalingan. From Circle, go to Quezon Avenue then turn RIGHT when you reach Banawe. Drive past Orthopedic, Chinatown Resto, etc. After crossing Banawe corner Retiro, go past Teriyaki Boy resto. Malapit na po sila dun. They When you reach Chicken Charlie resto on the right, they are the radiator shop directly opposite (on your left). Just look for Jorge or Jemson by name. The other people there are Proto (tint and all around), Roy (all around), Mong (tint and all around), Ling (assistant), Ador (radiator assistant) plus or minus other cast members.
    #199
    if you see the Sogo motel to your right, meaning lumagpas ka na.
    #200
    salamat sa inyo sir..galing na po ako doon.
    - Gauge cleaning with bulb + Labor
    - 2 Door Striker
    - Power Lock
    - Headlight
    my next stop will be alarm and cleaning of interior.
    Boss Otep akala ko nandoon ka eh.hinanap kita kay Jimson. sakto yun punta ko kakatapos lang ng ginagawa nila kaya ayun lahat sila nagtrabaho sa sasakyan ko
    eto pa malupit kulang ang budget dapat magwiwidro muna ako pero sabi niya ok na yan babalik ka pa naman. Kaya sir Otep kasama na ako sa mga may kulang sa kanya..yun may mga kulang pa daw kayo ng bahala..hehehe..
Jemson Thread [new number]
