Results 1 to 16 of 16
    Aug 2003
    May I know a place that fix instrument cluster? The gauges of my instrument cluster suddenly died (fuel, temp, speedometer, tachometer). LCD part and other indicators are working properly. I believe problem is on one of the chips.
    Car: 2002 BMW e46
    Try j6 banawe.
    That's the shop recommended by team fd peeps whenever someone's cluster gauge goes bongkers in their FDs
    to be or not to be, that always confuses me!
    Aug 2003
    Ok, thanks I'll try to contact them first.
    Oct 2016
    Gudam. Need help po. Yung electonics gauge po kc nung sasakyan ko nacra, can anyone help kung saang best place pra mapaayos un.. mitsubishi chariot converted model po. And nacra po kc ung electronics floater nya and may nangangamoy n gas n sa luob ng sasakyan everytime n tumatakbo ang sasakyan. Sana po may makatulong sken. Thanks in advance
    to be or not to be, that always confuses me![/QUOTE]
    ^^^ pakiulit yung post mo na WALANG TEXT SPEAK. read the rules, bawal yan dito sa tsikot. helpful lahat ng andito but you need to follow the rules.
    Oct 2016
    Ay sorry po... bago lang kasi ako naka join dito pasensya na po. Ang problema po eeh yung tangke ng sasakyan ko. Nasira yung sa pump floater nya na nasa luob ng gas then yung tangke, nagkapipi sya, mitsubishi chariot po yung sasakyan converted po sya ng right handed. Nahihirapan po maghanap ng pyesa ng tangke kasi yun na daw po ang kailangan , any suggestion po kung magkano ang buong tangke nun at saan makakabili? Kailangang kailngan lng po tlaga. Salamat sa sasagot.
    Sep 2008
    Quote Originally Posted by SiViTeC View Post
    Allow me to revive this thread, any update with your cluster gauge?
    Quote Originally Posted by Ruffa View Post
    kung nagka-pipe lang, at hindi naman pretzel-ized, ay puede pong i-un-pipe yan. ask around in the car parts strips like banawe or evangelista.
    i'll bet someone there will try to sell you a replacement assembly... at the price of an arm and a leg.
    if it is the float mechanism that got busted, it might still be repair-able. most of these are simple mechanical pieces. one just has to know where to bring it.
    also, manufacturer usually uses one model float for several of its products, to save on manufacturing costs. yours might be the exactsame model the other local mitsu models here, use. can you post pictures?
    i bet ninja knows how (to repair it).
    peace, ninj.
    Another thing is nang-hijack ka ng thread. You can create a separate thread about your issue so people can answer you on the thread that you created.
    Hi,
    Any leads or recommendations for a place that "repairs" gauge clusters?
    In my case, it's more of a mechanical problem. There are times the speedometer is noisy, like the gears inside are skipping/jumping teeth or grinding each other (not sure how to describe it, sorry).
    1993 Mitsubishi Lancer (itlog). Thanks.
    Quote Originally Posted by Blackbird View Post
    Hi,
    have you considered replacement with surplus?
    but you probably have to get the entire instrument cluster.
    ..."what am i gonna do with a speedometer-less instrument cluster?"
    Feb 2019
    Feb 2019
    nacra po kc ung electronics floater nya and may nangangamoy n gas n sa luob ng sasakyan everytime n tumatakbo ang sasakyan Audacity Find My iPhone Origin
    Quote Originally Posted by lala31 View Post
    please re-narrate. hindi ko masakyan ang mensahe at tanong. include make of car.
    nacra... na-c-ra.. nasira! nak nang... ano ba 'tong nacra nacra na ito?
    bawal text speak dito, po. maraming hindi millennials dito. heh heh.
    Oct 2019
    Try j6 banawe.
    Good day po sa lahat! Gusto ko lang po humingi ng tulong kasi yun honda civic 2001 ko, meron times na nawawala ang kuryente ng speedometer, fuel gauge, temp gauge and yun (d ko alam ang tawag) "P, R, N, D, D1". Bale nangyayari ito pag switch on ko ng ignition. Iilaw sya for a 1-2 secs then mawawala na at babagsak din yun mga needle ng gauges. After ilang minutes bumabalik naman. Pero ngayon matagal na d bumabalik. Akala nung tumingin na electrician ay yun relay sa ilalim ng glove box so pinalitan nya pero ganun pa din. Please help. Thanks in advance.
    Feb 2020
    precisely. I want to replace rather than repair thew gauges for my toyota BB 1.3 XL./ Problem is, as of 2020, there areno sources of surplus cluster gauges
Instrument Cluster Repair Service
