Results 1 to 12 of 12
    Feb 2005
    Anyone here have problem with their odometer and speedometer readings? meaning not accurate? Is the speed sensor the solution to this? or is there other options.
    My problem is my Automatic Tranny, and the mechanic said need to fiz first the speedometer problem for the tranny problem to go away. Thanks.
    Feb 2005
    The problem is that both tachometer and speedometer readings is not accurate, meaning when after driving for 30 min. my RPM goes down to zero while my speedometer is stuck at 30-40kph, thats in idle position only.
    Can you tell me what exactly is the problem or parts fix in your Transmission? Thanks//
    Feb 2005
    This is the panel display when after driving for 30 mins and when engine still cold or newly started respectively...
    Attached Thumbnails Attached Thumbnails 17238204_10208384044547426_999511298_n.jpg   17274420_10208384043227393_462331996_n.jpg
    Feb 2005
    Anybody here knows someone who fix gauge panel display like mine with pictures above? any inputs appreciated. Thanks/
    Quote Originally Posted by Innova_Boy View Post
    ...it looks like the connections are interchanged!
    has the dash been opened before?
    or trans...
    Oct 2013
    or trans...
    Toyota Techstream lang katapat nyan para mabasa direct ang laman ng ECU mo at macompare sa galaw ng panel mo. Ang tanung, ano ang mga ginalaw bago nangyari yan?
    Feb 2005
    It was opened back in 2012 for aircon evap cleaning. after the cleaning, the gauge panel was OK.
    Late Last year my tachometer is the first to act erroneoulsly, then this year the speedometer is also affected. That's the history of my ride.
    Thanks for any inputs..
    Dec 2009
    If you changed wheels with higher diameter then it will definitely affect your odometer reading
    Sent from my GT-P3110 using Tsikot Forums mobile app
    Mine before was the speedometer is not moving but tachometer is ok and at that time my ride is still under warranty. The whole instrument cluster panel was replaced for free.
    Anong model ba sa iyo bro IB ?
    Feb 2005
    It;s D4D G AT varaiant, top of the line way back then newly release of Innova 2005.
Innova d4d AT speedometer sensor problem..
