mga experts po dyan, I need your help. may problem po ang Honda Jazz ko 2005 model 1.3 IDSI ung kanyang Ignition Switch ayaw na po mag turn,na stock sya lock.
May remedyo po ba nito?
Saan meron magaling gumawa?
Need ko ng bumili ng bago?
Saan nakakabili nito?
what happen is nag pa duplicate ako ng susi sa SM booth..then unang gamit ko pag start ng engine sa parking lot then when i reach home and park the car, when i remove the key..may tumunog na kakaiba..then ayun na ayaw na mag unlock..
ginawa ko ay hire a lock smith..tatangalin nila yung ignition key assembly then manually they unlock it then they made a duplicate using their own key then ok na siya..been using the car eversince without any problem with the ignation..
that was 3 years ago..
also make sure you hire a good or trusted lock smith.
