I have nissan lec 93 model
nawala menor nya so namamatay
may problem pala sa electrical so nirekta ng mekaniko then ok na pag patay AC ok sakto lang ang idle but when i turned it on grabe ang lakas nd idle so yun grabe lakas sa Gas.
and 1 more thin pag nag rev ka na hindi naka gear ok walang pugak but pag naka gear any gear pumupugak pugak na sya
My Tagalog is not so good, but when it comes to any car, whether injection, carbs, etc, your idle is controlled by your idle control valve, which is also hooked up to your alternator to detect load on the electrical circuits and increase or decrease the rpms accordingly.
If you also have an air leak in your intake side this further shows up on idle and under load.
Please do not go directly to the ecu if your vehicle has one, as this should be a last resort.
A good auto tech can check your car in about 15mins to see what the prob is in general and then take it from there.
