Results 1 to 8 of 8
    Mar 2011
    why does my hand-break light lit everytime i take a turn? but when i go straight the hand-break light turns off. anyone have an idea? feel free to comment guys, any idea can help. tia!
    Jan 2010
    Quote Originally Posted by liteace 96 View Post
    hijo handbrake light indicate two things, either your handbrake lever is pulled up or your brake fluid is low....in your case it certainly indicates that your brake fluid is low....
    May 2010
    Try to check your brakes. maybe there is a problem.
    kung while on turning ka lang nagkakaroon ng brake light blinking at walang problem sa brake fluid, electrical yan. Pa-check mo na agad sa electrician. Baka may short sa electrical lines nung sa dashboard mo at yung sa turn signal lines.
    nagbaklas ka ba ng panel gauge recently?! baka nga may nagalaw or lose connections e.g. maluwag bulb?! have it checked asap dahil kakainis nga yan ilaw ng ilaw
    Mar 2011
    pinalitan ko lang yung horn(stebel air horn) from stock horn and mount it on the body. do you guys think its grounded? do i have to put realy for it? thankyou guys for the info.
    check mo muna yung handbrake mo sir, meron switch don, im not sure lang sa ride mo kung normally open or close siya, which serves as the trigger para mag lit yung bulb sa gauge... baka maluwag at pag nag turn ka ay gumagalaw kaya umiilaw yung gauge mo...
    Mar 2011
    sige sir thanks sa info, possible nga na maluwag yoon. ipapacheck ko na lang.
help! handbreak light problem.( in gauge)
