Results 1 to 6 of 6
    Aug 2009
    I have a 2002 Isuzu Trooper 4jx1 engine.
    1) my problem is ung temperate gauge ayaw gumagana - nasa C lang plagi kahit pinatakbo ko na? pinalitan ko ng water temp sensor, ganun parin. what do you think is the problem? pls help
    Feb 2009
    Quote Originally Posted by baby_scar View Post
    you probably replaced the coolant temperature sensor not the coolant temperature sending unit.
    Apr 2011
    Try to ground the wire that connects to the sending unit to determine if the gauge is working (very short time only as you don't want to cook your gauge). If it rises, replace the sending unit.
    Diba naayos na nila Jemson ito? Nakasabay ko po yung Trooper sa shop. Hindi lang siguro na update ni ts
    Jun 2014
    Got the same problem on my Corolla GL, 91 model. After ko ipagawa yung transmission, ayaw na gumana ng temp gauge. Di ko pa nababalik sa mechanic pero is there a chance na may matanggal na connection ng dahil lang sa pagbaba ng transmission?
    Quote Originally Posted by fox2lima View Post
    are the back-up lights dead, too?
    other functions that are dead?
    maybe the temp gauge and this other item, shares the same fuse..?
Water Temperate Gauge Problem?
