Results 1 to 8 of 8
    Jun 2006
    Ano kaya problem and ano dapat gawin sa problem ko sa headlights? AYaw kasi umilaw. Ang umiilaw lang yung sa right side and iilaw lang sya pag naka highbeam but talagang walang ilang ang dalawa pag naka beam lang.
    Nov 2007
    change your bulb pundido na low beam
    Apr 2008
    Quote Originally Posted by jansky View Post
    +1
    puede din baka nagloloose ang connection ng nasabing beam lights level
    Apr 2008
    Quote Originally Posted by jonski View Post
    pa check mo muna sa auto-electrician at isa pa makikita mo naman yan kung may pundi na ang light bulbs mo kung may putol or lusaw na fillament sa loob mismo ng bulb mo
    Sep 2006
    for the low beam, check the contacts of your switch...they might be loose or requires some cleaning already. for the high beam on one of your lights, it might really be busted already
    i assume double contact yung headlamp bulbs mo... and the best thing to do eh sundin mo yung pinost na payo ng mga nauna sa akin. check mo yung bulbs malamang busted na yung left side bulb mo at yung right side naman yung filament ng low putol na.
    palitan mo na yan...when was the last time na nagpalit ka ng bulb? simple lang yan pundido na ang bulb mo
    Aug 2007
    I had a Headlight Kit installed on my car to boost the its power a year ago. The other night..while i was driving..bigla nawala ang low beam ko. So i was forced to drive with High beam all the time...kawawa mga nakasalubong ko.
    Had it checked at banawe yesterday..checked the relays, bulbs, contacts, fuses....all where okay.
    what went wrong was the bulb holder. Medyo nalulusaw na. So got it changed with a ceramic type holder. 150 each lang. Buti yun lang problem.
Headlights problem
