Results 1 to 4 of 4
    Jul 2017
    Sir ano kaya problema nitong motor ko wlang kuryente yung wire ng headlight
    Sent from my Q894 using Tapatalk
    Quote Originally Posted by MC_RAIDER03 View Post
    siguradong walang kuryente? baka pundido lang ang bumbilya?
    if bulb is ok, check the contacts and connections. check also the fuse, po.
    Jun 2012
    Check mo din baka kinagat ng daga ang linya ng kuryente.
    May 2011
    the way i understand it, the vehicle in question is perhaps a motorcycle? there has to be problem with the fuse, the headlight, the switch, grounding or the conductors both the power side and the ground side. if you don't have the tools to do diagnosis, you can substitute with known good light bulb, or connecting an alternate graund wire, or if it does not respond, try connecting an alternate power supply wire
Headlight wiring problems
