Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Aug 2015
    Mga sir, tanong ko lang ano kaya problem pag start ko kasi ng kotse nagflicker yung headlights and domelight (other lights okay naman, hindi ko lang nacheck yung sa trunk and tail light) pero kapag umaandar after ilang minutes, ayos na yung ilaw. Dec 2014 napalitan un battery ko. Baka po may inputs kayo sa ganitong problem.
    Thanks po.
    Aug 2015
    Quote Originally Posted by cRane01 View Post
    Thanks po.
    Magpli-flick talaga yan sir.....dahil hinihigop ng starter motor ang halos lahat ng power to start up the engine.
    Dapat off mo muna lahat ng ilaw at a/c kung magi-start ka ng engine, mas lalo mong mapapansin ang flickering kapag mahina na ang battery mo. 😯
    sent from my Nokia 3210i
    Aug 2015
    Thanks Sir Mentis! Pero nagflicker sya kahit naka-idle. Naka-off naman lahat ilaw and A/C bago ko i-start yung makina.
    Aug 2015
    Check your alternator output without lights and a/c, then check it again na naka switch on ang lights and a/c.
    Baka nagraratle na ang output ng alternator mo, maraming factors yan like carbon brushes and lose contact of main wire terminal. Malabo naman ang terminal ng lights mo ang lose kung sabay sabay sila mag flick.
    Aug 2015
    Quote Originally Posted by Mentis View Post
    Thanks Sir Mentis sa advice. I'll check it later
    Aug 2015
    Nawala na yung pagflicker, baka low charge lang un battery during the time na nangyari yung pagflicker. Try ko pa din observe. Thanks!
    Mar 2017
    Mga Bossing! Sorry off topic. Newbie kc d ako makagawa bago thread. Anyway, paturo naman pano tangalin yun dome/reading light sa front ng Ranger Wildtrak T7. Eto yung may 3 lights tapos may motion sensor sa magkabilang dulo ng dome light assembly. Gusto ko kc palitan ng led yun bulb. Sungkit lng ba ito? San banda dapat sungkitin? Takot kc ako mabasag yun assembly. Thanks in advance.
    i don't have your car.
    but i find the owner's manual, useful sometimes.
    baka nandun.
    Aug 2012
    Quote Originally Posted by ElvisIsAlive View Post
    Post a picture of the dome light here.
    Sent from my D5833 using Tapatalk
    Mar 2017
    baka nandun.
    Sir, wala sa manual. Kasing kapal ng Stephen King novels yun manual kaso hindi tinura pano baklasin yun domelight. Nakalagay lng dun anong klaseng bulb dapat gamitin replacement.
    Mar 2017
    Quote Originally Posted by red_one View Post
    Ok Sir! Will post a picture. Salamat po!
    Mar 2017
    [QUOTE=red_one;2808882]Post a picture of the dome light here.
    Eto po yun picture ng domelight (front).
    Attached Thumbnails Attached Thumbnails 20170304_152659.jpg   20170304_152845.jpg
    Jun 2012
    Tuklapin mo yung lens na parang magtuklap ng talangka. Walang sekreto yan.
    [QUOTE=ElvisIsAlive;2808960]
    look at the manual, po, to see where the flat blade screwdriver is recommended to be inserted for sikwating. baka kasi mabasag kung sa ibang lugar.
    otherwise, "make a guess" where it should be inserted.
    Mar 2017
    Quote Originally Posted by confused shoes View Post
    Yup natuklap ko po yun plastic cover (clear cover). Napalitan ko na yun main bulb (center), festoon type. Problem is yun 2 sa sides. W5W (T10) kc yun at sa likod ng assembly ang kabitan na dapat buo assembly tatangalin. Anyway, ayaw ko na sungkitin pa. "If it ain't broke, don't mess with it" ika nga at baka mabasag pa! hehehe.
    Mar 2017
    [QUOTE=dr. d;2809047]
    Well sad to say wala instructions sa manual kun pano tangalin yun domelight. Pro ayos na yun hindi ko na gagalawin pa. Mahirap din kc yun malikot sa aparato, cgurado nasisira! hehehe
    Aug 2012
    Good to hear napalitan mo na ng bulb. Ano hitsura ng ilaw sa sides?
    Jun 2012
    Hilain mo lang yung bulb. Sa glass mo hawakan. Wedge yan. Hindi ka dapat magbaklas ng assembly.
    Mar 2017
    D ko na kc pinalitan yun 2 bulb sa sides eh. Pag force ko hila d kaya mabasag yun bulb at masugatan pa ako? hehe. Anyway, cge try ko. Tnx!
    Mar 2017
    W5W size T10, wedge, or sabi sa concord "peanut type".
Headlight and Domelight Flickers
