Results 1 to 12 of 12
    Ano kaya prob nito mga gurus
    Mahina yung ilaw ng oil warning
    With light
    No light
    Car is 2010 everest.
    Patulong naman po.
    #Retzing
    generic explanation:
    oil pressure is dependent on three things:
    1. oil volume in the sump;
    2. oil pump; and
    3. resistance to oil flow.
    you may be low on oil. it's easy to check this.
    is your oil pump ok? this, i know not how to check.
    your crankshaft bearings are so worn out, they offer little resistance to oil flow. this results in low oil pressure being generated. the oil light (in my experience) lights up but it tends to flicker.. translation: engine overhaul.
    Oct 2011
    ung ilaw ng oil pressure lang ata tinutukoy ni sir beni na mahina pagka start ng engine hindi ung lumalabas na oil pressure warning light pag tumatakbo na.
    ah, oo nga, 'no!
    teka, san ko ba naranasan yan? 'di kuna matandaan...
    Yung light lang nga. Natakot naman ako sa engine overhaul. Haha. Everything is working fine naman, yung light lang. Minsan malakas yan, minsan sobrang hina. San ko kaya pwede ipaayos yan?
    #Retzing
    Oct 2011
    Quote Originally Posted by beni23 View Post
    #Retzing
    tingn ko sir walang ilaw yan. either umilaw o hindi iilaw lang yan. out of warranty na ba?
    Jan 2013
    Patay makina sir? Pag patay makina normal lang na umilaw lahat ng indicator light. Pag bukas makina umiilaw din ba sir?
    Sent from my iPhone using Tapatalk - now Free
    Jan 2013
    Or kung concerned ka dun sa light mismo. Baka naman pundido lang
    Kung walang check engine, ok yan. Basta tumatakbo na at walang ilaw, no problem. Kung umilaw, low on oil. Check dipstick to make sure.
    Jul 2010
    May loose connection lang siguro sa supply ng battery terminal , ignition switch contact at fuse.
    Parang walang ilaw. Yung aninag ng ilaw sa madilim galing sa adjacent lighted peanut bulbs, Iilaw dapat yan when engine not running. Kung under 3yr warranty, claim mo na lang sa dealer. Pacheck mo ang pressure switch baka stucked or busted peanut bulb.
    Oil sensor problem. Nakuha sa change oil. Umiilaw na ngayon. Pinacheck ko yung gauge kanina sa may J6 along kaliraya street ok lahat ng leds. Hehe
    Out of warranty na siya. Til july lang warranty.
    #Retzing
"oil warning" light
