Results 1 to 9 of 9
    May 2008
    Guys, tulong lang po ulet.... I have a 95 toyota corolla gli ride. pauwi na po
    ako ngayon naka segunda yung gear then sa pagsampa sa humps eh namatay yung makina.
    totally wala po ilaw yung instrument panel ko like: battery, oil, and check engine lights.
    Dapat po eh nakailaw pa rin ito di ba? Kaso hindi po. Sign po ba ito ng grounding problem? Nagstart
    naman po agad kaso flicker yung headight pag nagbreak. thanks po sa ideas nyo.BTW, bago po yung battery at related sa thread na:http://tsikot.yehey.com/forums/showthread.php?t=57897
    May 2007
    Check your batteries. Maybe the wires in the terminals just came off. If that still doesnt work out for you. Try looking at the alternator. But you should really get a pro.
    Nov 2003
    yeah, sounds like the battery terminals are lose na.
    heropopo,
    try mong tingnan yung mga relays mo, baka maluluwag na sila sa kanilang socket. nakalog sila after ng humps eh.
    Feb 2009
    Quote Originally Posted by heropopo View Post
    heropops,
    if i were you, check the basics first. with this symptom, i would check the battery terminals first. these are supposed to have been checked everytime you do a preventive maintenance checks and services as what is termed in the pilipins as pre-menstrual syndrome or pms. these terminals are supposed to have been cleaned and checked for voltage drops across the battery posts and the cable ends or clamps. this should not exceed 0.1 volts across each connection by standards. then after cleaning them, seal them with battery terminal sealer or the most common is the petroleum jelly or vaseline on top of the terminals where they meet with the battery posts to seal off oxygen from the ambient air that accelerates the corrosion from the battery electolyte. then, on toyotas, check AM1 and AM2 pacific fuse( usually pinkish). these are higher amperage rating fuses right next to the cable clamps on the positive side(no fuses on the negative side, hahahaha). check these for tightness and corrosion. if you see some corrosion, you can use simpel grin multi purpose cleaner on the terminals and be careful not to introduce the slightest trace of this concoction into the battery. it kills the battery in two hours. in the absence of simple green, you can use Coke or Seven Up, the carbon dioxide in them removes the corrosion. just rinse with plain water or the ants will attack your battery. then the petroleum jelly thingy or the vaseline thingy thang to prevent further corrosion. the weakest part that usually cause this symptom is not the grounding(except the battery post of the negative side which is closest to corrosives) but the positive side. any more questions?
    jick
    May 2008
    thanks po sa reply nyo... pinakabitan ko po ng grounding kit yung auto ko ...just followed the ones posted here...so far stable na yung car. thanks
    Jul 2005
    bro, magkano yung nakuha mo na grounding kit? how much labor for installation also?
    Jan 2009
    sa blade robinsons manila meron 5 point grounding kit using 8awg wires, 390 pesos daw. kaso hindi ko binili kasi nag DIY ako.
    May 2008
    800 yung grounding kit ....labor fee naman eh 180. Sulit na. Na-solve na yung problema. Thanks.
Grounding Problem kaya?
