Results 1 to 10 of 10
- Aug 2010
- 38
November 21st, 2011 01:22 PM #1Good day!!
I have audio setup on my Honda City 2004. Newly installed palang ito last two weeks. During the first week of breakin, ok naman yung tunog. We made some modifications sa mounting ng tweeter (nilipat lang ng pwesto). Problem now after installations, nagloloko yung balancing ng seps (Left-Right).. Nawawala ung Left seps-tweeter kapag open yung Left door. Pero pag sinaramo na yung door, tumutunog na ulit kaso pag malakas na yung volume, medyo bumibitaw bitaw ulit. Pioneer AVH-2350DVD gamit kong Head unit. Nag try na din kami mag isolate using ipad na nirekta na namin sa amp to check RCA/AMP/CrossOver/Seps-tweeter ang problema pero working fine lahat. kahit iswing mo pa yung door di bulibitaw. Iniisip na lang namin na baka grounded yung Left Door ko na in a way parang connected siya sa HeadUnit. (Pano kaya nangyari yun? Grounded yung Chasis nung HeadUnit na si door ang trigger? Grounded yung Antena ng Radio na si door ang trigger?) Kasi pag Ipad rekta sa amp to seps-tweeter ok lahat pero pag HeadUnit na source, bumibitaw bitaw pag nagagalaw yung door.
Ano kaya sa tiningin niyo sir? Need your help...
Thanks!
- Aug 2010
- 38
November 21st, 2011 02:25 PM #3Binalik ko na sir kaso di namin mahanap yung problema. focus namin yung sa wiring sa door then yung headunit alone. weird kasi.. dami na din napupundi na ilaw sakin before ako magpasetup.. mga 3 times na.. ibat ibang ilaw.. wiring siguro to.. sana wag yung headunit kasi mahal..
November 21st, 2011 07:07 PM #4
Baka may sira nga electrical mo. try mo dalhin kay jemson. sa banawe.
November 22nd, 2011 02:09 PM #5
sa tingin ko grounded yung wirings mo, pa check mo na lang sa auto electrician, madali lang nilang ma trace yan
November 22nd, 2011 03:18 PM #6
There's definitely a problem on the speaker wire going to that door. It might have been pinched or abraded and either shorting each other or the metal door (ground) when it is opened.
You should have this fixed asap or you might just destroy the HU.
- Aug 2010
- 38
November 22nd, 2011 06:02 PM #7Nacheck na namin yung wiring from amp to seps-tweeter using direct ipad as source. Walang problema sir kahit iswing ko yung door.. Iniisip ko kung pano nagkaroon ng contact yung HU ko sa door / chasis kung grounded man siya? Tinanggal ko na din muna yung antenna baka kasi grounded din kaso same problem...
November 22nd, 2011 06:33 PM #8
check the other parts like door switch and window riser electrical system..
- Aug 2010
- 38
November 23rd, 2011 10:46 AM #9most likely sir nasa magkano pagawa ng grounding/wiring problem? pag total rewiring, nasa magkano kaya?
- Apr 2010
- 46
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
