1. Doing the big 3 upgrade. Alternator is 140 amps. Wire size is 4 guage, with amp capacity of 150 amps. Should I use a 140 amp to protect the wire and alt?
2. Running a 4 guage wire from the battery to my amp. Amp is protected by a 60 amp fuse. What fuse size should I use put right after the battery? Its to protect the battery, the wire, the car and me, not the amp.
, you really wanted a high-output alternator anyway, right? It is also a good idea at this point to measure resistance of the new cables. Take an ohm reading between the battery end of the new ground cable and the engine block. It should read less than one ohm. Also check between the alternator bolt and the disconnected positive battery terminal, which should also be less than one ohm. If you read too high resistance, double check all connections and make sure you do not have something c**ked sideways or hanging loose.
Examine the engine compartment and make sure none of your cables are getting hot or are vibrating or shaking around. If they are vibrating too much you may need to relocate them or use more cable ties. If you see smoke, immediately shut off the car and disconnect the battery. Seek help.
