Page 1 of 2 12 LastLast
Results 1 to 20 of 30
    Aug 2007
    Mga experts....umiilaw yung battery indicator sa dashboard. AT yung car.....
    Pero nung check namin yung battery mismo doon sa sight glass nya eh color green pa...
    so yung alternator na ang problem? Umiilaw ba talaga yung battery indicator sa dashboard kahit alternator ang sira?
    Aug 2007
    ^ Yup, I think thats the symptom of a faulty alternator. Maybe the current is not anymore stable or low thats why the indicator is blinking.
    I reckon that you should'nt be traveling very far away with a faulty alternator.
    Aug 2007
    Quote Originally Posted by DonT View Post
    Thanks......Yes hindi na ginamit yung car kanina....
    Sir linawin ko lang....kailangan blinking or kahit steady lang?
    Aug 2007
    Quote Originally Posted by suv View Post
    Sorry..from my experience kasi..it was going on and off intermittently..kaya tuloy I wrote blinking sa earlier post..pero in the end..kapag sira na talaga..steady na yan..pati yung car steady na din.
    Aug 2007
    yung sa amin kasi steady habang umaandar kami....pero malapit na kami sa bahay....
    advisable ba yung surplus na alternator?
    Magkano estimate ng brand new casa alternator vs surplus?
    May 2007
    A very good experience and a good answer.
    * SUV......Check engine light is emissions system problem. However, when the brake/batt. dash lights when the car is idling appears that this is a good indication that your alternator is dying (alt. belt tension sometimes) and not charging you batt with proper voltage. ECU diagnosis can helps you a lot.
    yup, there's a problem with the charging system. original alternators are better but the one you have may still be fixed. have it opened and checked. carbon brushes may be worn out and they're fairly easy to replace. if it's the IC then it depends. have it checked first. it might just be a faulty connection or a belt that needs replacement/tightening.
    Jun 2006
    Alternators can be fixed. Hopefully its just the carbon brushes or a loose belt. Mura lang ang carbon brush. Have it checked by a competent auto electrician.
    Mahal ang new alternator. A friend of mine had his replaced at a Nissan dealership. Price was 18,000 pesos.
    Aug 2007
    Maraming salamat sa tulong nyo dito.....pwede pala ayusin....
    Meron pala belt yung alternator.....so sige ipapacheck ko bukas....sarado kasi kanina.....
    Thanks ulit....
    May 2005
    Kung alternator problem
    lumusong ka ba sa baha before ,,baka inabot ng tubig ang alternator mo may nag short doon ,pwede nasira na din ang IC ..
    gaya ng sabi ng ibang poster pa check mo din tension ng belt mo sa alternator
    wala ba annoying noise sa alternator before may umilaw sa dash mo
    Aug 2007
    Other causes outside the alternator may include loose electrical connections or a busted/faulty power regulator.
    Aug 2007
    Quote Originally Posted by BoEinG_747 View Post
    hindi naman lumusong sa baha.....Pero pag naka-idle eh may tumutunog na hindi ko maintindihan....parang rattling sound sa loob ng hood sa harap ng manibela....pero pag nakaidle lang yang tunog....pag umandar na eh wala na tunog...
    May 2005
    check mo din condition ng belt/tension at idler bearing .
    may bearing din doon sa alternator
    Aug 2007
    so meron din palang tensioner bearing ang alternator.....thanks ah...kasi ang alam ko lang tensioner bearing eh yung kasabay ng timing belt na pinapalitan pag naka 80 thou kms...
    Dami ko talaga natutunan sa tsikot.....
    May 2005
    brod ibig ko sabihn ay tension ng belt mo,baka maluwag kaya may langitngit sounds , at baka may sira na din ang belt mo kaya pa check ko sa iyon condition nito
    at doon na naman sa idler my bearing din doon ,baka may tama na din
    May 2005
    Re: Battery indicator sa dashboard
    wala ba nakasulat sa manual ang mga ganyan fault kung ano problema
    tapos my countermeasure doon kung ano dapat gawin ba
    Aug 2007
    Sorry ah kasi newbie talaga ako pag dating sa parts ng car...
    lahat yan regarding sa alternator? I mean merong alternator belt, bearing? Ano pa parts napapalitan sa alternator?
    Wala ito connection sa timing belt and tensioner bearing?
    Hindi ko pa makita yung manual...hanapin ko pa....
    Thanks again....
    Aug 2007
    sir BoEinG_747
    pinabasa ko sa kakilala ko yung post dito kasi meron ako hindi magets regarding sa parts....Tension pala ng belt.... kala ko kasi tensioner bearing...
    Kinabahan ako kala ko sira na din timing belt and tensioner bearing.... yun pala yung belt sa alternator and yung bearing nya
    Pasensya na kayo lahat....ang konti pa lang ng alam ko sa car....
    if it's due for replacement, better to buy brand new, mas mahal pero sure ka naman...kesa sa surplus swertihan dyan minsan mas mapapamahal ka pa dahil makakadalawang palit ka..wait ano ba car mo? meron akong nakikita sa true value nagbebenta ng mga alternator...
    Aug 2007
    Sir sa father ko yung car. Lancer GLXI 97 AT
    magkano ang pinakamurang brand new nito? Pero sana maayos pa para hindi magastos kasi bibili kami bagong car eh....
