hi guys gaano ka importante maglagay ng fuse para dun sa battery para sa sub woofer ung akin kasi walang kinabit... para san po ang use nito?para lang ba sa pang protect short circuit?
You must install a fuse within a few inches of the battery. That fuse is to protect your car not your sound system. Its job is to blow and cut power from the battery in case there is a short or your power cable is grounded. If you have a short and no fuse.......... :boom1:
Make sure you buy and install a waterproof fuse holder. Its not expensive. I bought mine for around 200 pesos. The fuse amperage must be a higher than the total ampers of your amp/s.
The fuse on your amp, if it has one, is there to protect your amp. If your amp is not fused, install one a few inches from your amp. No need to install fuse on speakers.
makiki-ride lang po sa thread:
sir where can we buy waterproof fuse holders? tsaka pano ba yun install?
wala rin kasi fuse yung sakin... i'm planning to install one, though. nakakalimutan ko nalang kasi medyo busy sa school. actually, when we installed my amp, the wiring kit i bought came with a plastic fuse holder. di lang ako sure kung waterproof since Euro R lang sya. la naman problems sa system ko, pero iba parin may fuse...
thanks!
Thats the one you have to use, that plastic fuse holder. Cut your power cable(red cable) no more than 20 inches away from your battery, splice your cable apprx. 3/4 of an inch both end, slide that cable to the opening of the fuse holder tighten the hex screw, secured your fuse holder. You may have to buy fuse if dont have one.
Observe safety rule. You must disconnect the battery before start the job.
ok sir... ilalagay ko na rin fuse as soon as i can.Originally Posted by v6dreamer
here are some pics of my fuse holder... pasado na rin kaya ito?
natutunaw yun sir? dahil sa init ng engine? san po kaya maganda ilagay yan? kasi yung auto ko lovelife corolla... yung battery nasa likod lang ng driver's side headlight... :?
one time may nagsabi sa kin maganda daw yung fuse na nabili nya dahil matibay! ngeee!
