Results 1 to 12 of 12
    Aug 2010
    will there be a problem if the alternator was flooded? so far stereo, lights, horn are working fine.
    how do you if the alternator needs repair?
    Quote Originally Posted by trucker111 View Post
    Best to have it checked by an electrician, water could've seeped in and damage some parts later.
    Jun 2010
    let it be, if it aint broke dont fix it ika nga, just let it air dry then observe.
    Feb 2013
    Kung may problema alternator, hindi magcharge ang baterya mo.
    Jul 2010
    Once natuyo na yun tubig at nagamit mo naman na hindi na discharge battery ay ok na iyan.
    Ang kasunod lang niyan ay mag iingay na yun alternator bearing dahil sa tubig na pumasok. Depende kung matagal nalubog. Around 800.00 parts and labor ng palit bearing ng alternator.
    Jun 2006
    Kung sira charging mo, iilaw ang red battery light sa dashboard. Pero its still not a sure way of knowing since hindi din yon iilaw as long as may meron ka pang small charging capacity.
    Its either meron or wala lang. Malaman mo is lagyan mo ng tester ang battery mo, then start,pag tumaas , value should be 13.8 to 14.5.
    alternators are generally built to last. many will outlive the engine..
    they get wet a lot more often than you can imagine.
    just drive your vehicle and don't think about it. the alternator will tell you when it needs servicing.
    Oct 2011
    pag okay naman alternator at nag chcharge wag palitan. normally ung bearing or pulley naman bibigay and you will hear unusual noise sa engine hood mo.
    Brushes and sliprings lang ang exposed sa electrical part. Regulator at exciter diodes ay sealed, so not unless you operated the alternator submerged for a long time, you have nothing to worry. It will take longer to short-circuit a low voltage supply while submerged. Try mo lubog battery sa tubig, pag ahon mo may kuryente pa rin. Ang masisira lang incase ay bearings kung medyo wala na grease that serves as water insulation. Pulleys have bearings.
    Aug 2010
    a mechanic advice me to have the alternator and starter check and clean. he told me not to wait until something happen. mas malaki daw ang gastos. maganda daw yung stock alternator and starter ko. he said its ok for now, pero pag natuyo na ang tubig at kalawang, dun na magkakaroon ng problem.
    tama ba siya?
    Mar 2013
    tama ba siya?
    Yes tama ang mechanic mo.
    Aug 2010
    i went to this auto electrical shop. ask them to check the starter and alternator.
    true enough, the starter has lots of rust inside and parts are grounded. i was told that its just a matter of time before it starts to degrade.
    the alternator needs cleaning. meron parang white powder inside. i was told that it is a sign of flooded alternator.
    total damage is P2.3K.
Flooded Alternator
