Results 1 to 7 of 7
- Sep 2008
- 596
July 30th, 2022 10:35 PM #1I was running the engine in the garage and was switching the flash to pass signal in the stalk towards me three times and was working and the next time I did it, it was not working anymore which includes the dashboard indicator. What could be the problem? Does this function also have a relay? All other electrical functions are good including the hi and low beams (even the dashboard hi beam indicator is working), signal indicator and hazard lights. I also checked the fuse, and it is good. What could be wrong? Could it be the stalk?
- 54,285
July 30th, 2022 11:23 PM #2
- Sep 2008
- 596
July 31st, 2022 09:09 AM #3thanks for the reply, its a MB w202 C220. Funny, this morning, I tried it again and it worked but after 5 tries, it stopped and it went back okay again. I was wondering if it has a relay since I cannot seem to notice it, was hoping someone can advise me if there is. Otherwise, it must be the contacts of the stalk but google said there is no easy fix but to remove the steering wheel to access the terminals so I can clean it up if I wanted to. Just having second thoughts as I might break something, hehe
- Jan 2008
- 4,726
July 31st, 2022 07:46 PM #4What car model? Some have relays, some dont.. the stalk is directly switching the lights..
- Sep 2008
- 596
- Jan 2008
- 4,726
August 25th, 2022 12:30 PM #7
^ Ako I just use the good ole mini elm327 OBD2 scanner. Pero usually sa long drives ko Lang...
