Results 1 to 4 of 4
    Jun 2007
    last night parang nasira yung lock ko. parang ayaw mag lock kasi "stuck" siya kapag naglolock ako using the remote. yung isang lock lang (kabila naglolock).
    then kaninang umaga i tried fixind it. nilgyan ko lang ng WD-40 tapos parang pinapalambot ko. ayun when i pressed the lock button, nasira na yungparang "motor". may sound na parang "arrrrrrrrrrrrrrrrrr" parang ganun. or actuator tawag dun. basta ganun.
    so what should i do? buy a new one? or kaya pa yun magawa? sayang naman eh.
    thanks!
    Aug 2007
    Quote Originally Posted by rockstaremya View Post
    thanks!
    tsk tsk tsk poatignan mo muna sa mga electrician baka maayos pa nila yan
    Dec 2003
    papalitan lang ang door lock actuator nyan, dami sa banawe mga mura masyado pero ok naman ang durability.
    dali lang yan palitan lalo if your actuator is the same as the cheap ones. kung orig pa actuator mo, just have it removed then replace with the new one (kelangan magbutas to mount the new actuator) then rewiring lang, ok na.
    nangyari din sa akin yan bro.
    what my mechanic did is to clean the actual mechanism sa actuator. yes binuksan nya yung actuator and nilinis.
    gumana sya.
fix my power locks/alarm
