Quote Originally Posted by v6dreamer View Post
Check your alternator belt maybe experiencing amount of belt slip. Sometimes fuzzy connection in the HOT wire or BAD ground is the first place to look. Check all your wire connector from alternator to rectifier and solenoid and clean w/ non conductive electrical cleaner or WD 40 and remove all corrosion in the connector.
There so many possibilities about erratic Tach. This is your basic things to do. If this thing not work as I mention above let know and Ill give you step by step how to trouble shoot your Tach. Good luck.
thank you,sir....i'll keep you posted pagma'check ko na un mga wirings.
