Results 1 to 4 of 4
    Good morning,
    Ano kaya problema ng kotse ng utol ko, during highway speeds going to lipa bigla na lang parang pumapalo siya o nagincrease ng speed (jog lang)samantalang same naman yung apak sa gas, pumapalya ba spark plugs, carburator o cables, tsaka baka may nakakaalam po kung ano ideal resistance ng ignition cables ( stock ),
    thanks in advance
    could be because of the following:
    1. clogged fuel filter
    2. defective fuel pump
    3. dirty carb / ari cleaner
    4. faulty ignition system (plugs, ignition cable, coils, contact points, condenser)
    Ideal resistance? Kung pede 0 ohms pero may resistance din talaga yan.
    Oct 2004
    check the timing na rin po... baka tope lang yun....
    Spark plug cable resistance can't be too close to 0 because it will cause interference to your in car electronics. The spark plug cables are designed to have some resistance/inductance to prevent electromagnetic interference and skin effect. That's the reason why if you'll examine the cable inside, you'd see it on a spiral pattern, and not straight/stranded pattern.
    Ideal resistance per cable (terminal to terminal) should be less than 25K Ohms...
    EssB,
    Thanks for the info.
erratic power when cruising
