Results 1 to 3 of 3
    how would you know if there's enough electricity running through the HT wires and plugs?? may procedure ba kung pano ma check
    Nov 2003
    if you're not stalling or having any problems with the car then there is no need to worry
    Jan 2003
    While the engine is running, one by one, disconnect the HT wire from the spark plug. It should have a noticeable effect on the engine's run. If it doesn't, either the spark plug or the wire has problems.
    Also, inspect the running engine in the dark. Kung may nakikita kang sparks kung saan nandun yung HT wires, terminals, etc, then you have an electrical leak.
engine electrical sys
