Results 1 to 12 of 12
    Oct 2007
    san po nakakabili ng "electrical contact cleaner" at anung brand..yung panglinis ng MAF sensor..pde kayang i-DIY yung paglinis/spray nito?
    Jun 2006
    available yan at most hardware stores. dont know if it can be used to clean MAF. wait for someone more knowlageable to answer.
    Mar 2003
    there is a specific maf sensor cleaner already. dunno nga lang if it's already available here. the brand is crc. visit www.crcindustries.com
    Oct 2007
    nakuw..sana yung local brand lang sana pero garantisado ang effectiveness.hahah! kasi kapag nagkamali, imbes na malinis yung MAF. masisira pa.
    May I ask why do you need to clean the maf sensor? may symptoms ba like erratic idling, low pickup, etc?
    Oct 2007
    ang pangit ng idle eh..nakapatune-up na ako but still ganun parin.sabi nila baka sa MAF sensor daw.kaya napag-isipan kung ako nalang maglinis nito kasi pede naman daw i-DIY.
    ah ok...nakikita ko sa M111 engine ko they just remove the maf sensor and spray it with contact cleaner. pero once lang ito ginawa. nothing happened naman. erratic pa din yun idling ko, what i did was remove the temp sensor from the intake hose and sprayed it with carb cleaner. give it a blip of gas, ayun tumino ang idling.
    Sa SM ACE at Handyman Trinoma meron. That's where I bought mine. Mga Php300.00. I used it to clean the MAF.
    sa store namin meron ... pero usually sa banawe meron yan eh .... mga 250- 300 yung price .... try mo sa mga accessories usually meron yan .....
    kung wala ka mahanap drop by ka sa store namin meron kami niyan
    BANAWE AUTO SUPPLY
    regy
    Oct 2007
    ayos! thanks mga sir!
    Nov 2003
    on most mafs you can use carb or brake cleaner to clean them.
    Aug 2006
    Try NTS contact cleaner ung nasa green na bottle sa mga True Value hardware siya and you can use it as an engine degreaser as well
electrical contact cleaner?
