Results 1 to 5 of 5
- Sep 2010
- 15
June 6th, 2011 01:47 AM #1nasiraan ako sa may bandang cavite (pauwi na sana ng Metro Manila) buti na lang may tumulong at at nag dala ng mechanic. The mechanic found out na alternator yun at inayos nya yung alternator.. May lininang sya sa loob ng alternator nakita ko na may putol nga'ng wire.. sabi nya ok na daw un at tatagal na. Nung ginamit nmin ulit sure aq na nag fail nanaman yung alternator. Kasi nawalan ako ng busina humina nanaman yung mga ilaw at hirap na gumana yng power windows.
Mga pre gusto ko na bumili ng bago alternator. Ano ba dapat iconsider kung bibili ka ng alternator? kung ilan amp, ano muna dapat icheck sa electrical bago maginstall nun. Anung magandang brand din pala yung kaya mag supply ng full load(pag sabay sabay ginagamit ang a/c, stereo, headlight in high beam etc..) pati pala yung present price ng alternator..
tnx!! waiting for your advices.. ^^,
June 6th, 2011 08:26 AM #2
kung naka heavy load setup ka like sounds and light accessories, you better get a higher alternator rating... but kung normal load lang naman, buy ka nalang surplus... price range is 1.5k to 3.5k depending sa ride mo....
kung bago yung ride mo, however, baka wala pa surplus. ang choices mo lang will be to buy new one from casa or to have your broken alternator repaired...
- Nov 2009
- 14
June 6th, 2011 08:37 AM #3Yung amperahe at klase depende sa modelo ng sasakyan mo. Kailangan naka match. Kung maraming mga electrical equipment na sensitive sa over voltage, kagaya ng aircon, stereo, GPS, mabuti na kunin mo yung alternator na IC (Integrated Circuit) type para protektado yung electricals mo. Mahal lang nga. Kung dyip lang siya na walang aircon, kahit Voltage regulator type nalang, okay na yun. Maari ring ayusin yung luma mong alternator. Baka carbon brush lang ang papalitan. Mura yon. alterenergy.systems*gmail.com
June 6th, 2011 08:51 AM #4
- Jul 2008
- 935
June 6th, 2011 08:58 AM #5[SIZE="4"]Tol, you might want to try looking sa Handyman ng Alternator na para sa sasakyan mo. Mayron kasi silang 1 year warranty sa alternator sila at marami silang variants for different models. Syempre kunin mo yung IC regulated para kahit magpalit ka ng mas mataas na ampere eh hindi mag-oover voltage yung chrage niya...[/SIZE]
Yes, because 100 degree boiling point is measured at sea level. What's interesting also is that...
