Results 1 to 7 of 7
    Sep 2008
    I was running the engine in the garage and was switching the flash to pass signal in the stalk towards me three times and was working and the next time I did it, it was not working anymore which includes the dashboard indicator. What could be the problem? Does this function also have a relay? All other electrical functions are good including the hi and low beams (even the dashboard hi beam indicator is working), signal indicator and hazard lights. I also checked the fuse, and it is good. What could be wrong? Could it be the stalk?
    Quote Originally Posted by jakewise View Post
    well,
    if everything else checks out ok,
    then it must be the stalk switch.
    google it, sir.
    baka may easy troubleshoot-fix.
    errr,
    what car, po?
    Sep 2008
    well,
    google it, sir.
    errr,
    what car, po?
    thanks for the reply, its a MB w202 C220. Funny, this morning, I tried it again and it worked but after 5 tries, it stopped and it went back okay again. I was wondering if it has a relay since I cannot seem to notice it, was hoping someone can advise me if there is. Otherwise, it must be the contacts of the stalk but google said there is no easy fix but to remove the steering wheel to access the terminals so I can clean it up if I wanted to. Just having second thoughts as I might break something, hehe
    well,
    google it, sir.
    errr,
    what car, po?
    Jan 2008
    What car model? Some have relays, some dont.. the stalk is directly switching the lights..
    Sep 2008
    It is a MB W202 C220 1997 model
    Feb 2009
    do you need the wiring diagram?
    Jan 2008
    Better to check the stalk switch.. check the contacts.. clean with a fast drying contact cleaner..
"flash to pass not working"
