Results 1 to 4 of 4
    Just have my budget meal set-up installed. It includes seps, sub, amp & HU.
    I also installed a higher watts of headlight 100/90 with newly installed relay & wiring.
    My problem is when I use my set-up, my headlite and the aircon, the battery warning signs blinks and eventually pag in off mo na sa ignition, di na nag start.
    My mekaniko suggest that I change my alternator to a higher ampere, currently im using 55A for my corolla 91.
    Ive change na din a fully charge battery pero na dedrain especially at night when I use the whole system.
    Whats the best amphere that u can suggest guys na kakayanin lahat ng load?
    I appreciate ur info on this..
    Thanks
    Feb 2007
    Use a 90Amp alternator. :-)
    Jul 2006
    Get the biggest you can with the least modifications to the alternator mounting. Also a good idea to probably upgrade alternator wiring.
    Quote Originally Posted by mcclement View Post
    I already left my car sa electrical shop. they will installing a 110A daw, but I guess the highest is 90A, cost me 3500 for the surplus alternator.
    Thanks for the inputs
Drained Battery
