Results 1 to 7 of 7
BANNED BANNED BANNED
- Jul 2003
- 2,267
October 16th, 2003 09:35 PM #1i need ur help brus. sira yung aircon ng kotse and since wala pa ko pera eh ndi ko muna pinapaayos. patay muna yung thermostat (?) para magamit ko pa rin yung fan. unfortunately, mejo natagalan yung pag gamit ko ng fan while the engine is not running. nag hard starting ako kasi mukhang nadiskarga baterya. napastart ko naman yung kotse. kaso after that incident mukhang hard starting na lagi kahit kakapatay lang ng makina. minsan clicking sound lang ng starter naririnig ko although minsan nag one click siya. nagstart konting pilit lang.
bakit kaya ganun??? kelangan na ba palitan yung battery??? ndi ba siya narerecharge ng alternator??? motolite maintenance free yung bat at corolla gl 92 yung kotse. may iba kaya problema bukod sa battery like alternator etc.... salamat mag bru!!!
October 16th, 2003 11:58 PM #2
first check the battery connections, they might be either loose or badly corroded.
- Mar 2003
- 82
October 17th, 2003 02:39 AM #3yup, check the batteries, baka nde na narerecharge.
check also ur charging system. hth.
October 17th, 2003 09:27 AM #4
Flatting out a car battery cannot be full charged by your alternator alone. You have to bring it to your suking Motolite dealer to charge and check the battery for any damaged plates sustained. But I seriously doubt it would not do that on first flat out.
Anyway, charging it back and checking the battery is absolutely free.
- Jul 2003
- 2,267
October 17th, 2003 07:43 PM #5so pede ba pa recharge yung maintenace free??? try ko maghanap ng motolite dealer dito. salamat.
October 17th, 2003 11:55 PM #7
ganyan din nangyari sa amin... ginagamit yung extra fog-light at di pala kaya ng alternator yung additional load ... since motolite MF yan.. check mo yung indicator nya..
pag RED eh discharge na..
pag WHITE - halos half charge lang
pag GREEN - ok ang battery at charging system
yung sa amin dati eh nag RED at mahirap ng i-start .. then ni-charge at naging GREEN .. after that eh wala ng problem..
Automatic po Sir
