Page 1 of 2 12 LastLast
Results 1 to 20 of 31
    Guys... what brand of & where can I buy a digital voltmeter that can plug into the cig lighter?
    Like this:
    Thanks!
    Dec 2003
    hmm have not seen dig. voltmeters that plug into cig lighters, but digital voltmeters used in sound setups could be DIYed/wired to plug into cig lighters using cig. plug adaptors..
    got a digital voltmeter from Quest at KAC... it's the rectangular one in the pic below...
    both plugs directly to the cigarette lighter socket...
    bro... how much yan? may contact number ka nung quest?
    thanks!!!
    May 2004
    peep, here's his contact and price the last time i inquired...
    rect: 1,200.00
    round: 1,400.00
    0916-7212208
    sori.
    para po ba saan yan?
  7. #7
    me also wants to put a voltmeter on my van....this is much better in monitoring your car's charging system, unlike the somewhat useless ammeter..
    my prob nalang whether analog o digital ikakabit ko? ang prob kasi sa digital, daming components than the analog type...
    Concorde has them also. But they seem brandless and the displays are not that nice.
    May 2005
    meron din yata kay Jeff Tan nito (araneta car accesories)
    Jun 2005
    Quote Originally Posted by CLAVEL3699
    sori.
    Tatanungin ko rin sana kung anong gamit niyan, kaya lang nuunahan mo ako.
    pwedeng indicator ng batt voltage
    pwedeng burloloy sa loob ng sasakyan
    Apr 2006
    odinary VOM would do the job. Around 350 petot lang ata ung mga china made. All around usage pa. hehehe
    Oct 2005
    Thanks people.
    Ngayon ko lang nalaman na mayroon na pa lang voltmeter na pwede i-plug sa cigarette lighter.
    May 2005
    Quote Originally Posted by lakay
    Digital voltmeters are instruments that measure voltage or voltage drop in a circuit. They use solid-state components and display values digitally
    Jun 2005
    sir's I'm intersested also, kindly post the shops name and address.
    Quest Audio???
    Thanks
  16. #16
    ang disadvantage ng portable VOM is di mo siya pwede imonitor kung nasa biyahe ka na... unlike yang permanent, anytime ka tumingin, humahataw ka sa highway, o stuck sa traffic, mamomonitor mo talaga kung maganda ang karga ng alternator mo... dapt maintained kasi ung 13.5v-14.5v kahit na full load upang maiwasang madrain ang battery mo...lalo na kung naka av setup ride mo...
    madzie71, accurate po b ung digital volt meter? d po b dapat baba ng 13.5v kht full load?
    Jan 1970
    for proper monitoring, dont you need 2 volt meters? 1 for battery to make sure it can still sustain the 12v, and 1 for the alternator, to make sure that it is delivery enough voltage to charge the battery.
    Oct 2004
    Quote Originally Posted by slip-slick
    since they are connected in parallel, they will always have the same reading (assuming di significant ang losses sa wires ha...)
    nakabili n ako ng volt meter. readng nya 12-13v kpg full load. ok lng b un? d b mababa?
Digital Voltmeter
