Results 1 to 4 of 4
- Nov 2008
- 70
April 5th, 2010 08:04 AM #1Mga Sir,
I am not sure kung this is the proper section to post this.
However, I have already tried replacing all bulbs, all were tested to be lighting up. I have already tried swapping FUSEs, all to no avail...
Umiilaw naman yung sa dashboard panel, but hindi na sya mai-adjust to go bright...
Napansin ko sa malaking bulbs lang yung issue na parang kulang ang kuryente to go bright... dahil yung sa ibang sensor lights, lalo na yung maliliit ang bulb na gamit, ok naman sya...
any inputs?
TIA
April 5th, 2010 08:33 AM #2
check and clean mo yung rheostat switch (sa headlamp switch on most cars). kadalasan marumi na, if burnt out na, time to replace the switch
- Nov 2008
- 70
April 5th, 2010 10:46 AM #3*t2erns
eto ba sir yung nag-adjust ng dim/bright nung dashboard panel or mismong switch that we twist to turn headlights on?
April 5th, 2010 02:31 PM #4
high idle RPM at engine start
