Results 1 to 3 of 3
    Apr 2011
    Sir, may problema yung power windows sa right side(front and back)(same side). Sa front, minsan gumagana. Sa likod, hindi talaga.
    Sakop kaya ng computer box yung power windows? Plano ko pa lang kasi bilhin itong kotse. Balita ko kasi mahal ang computer box. please advice
    Feb 2009
    Quote Originally Posted by topgun18 View Post
    your power windows system is fully separate of the pcm. the possible problem areas for the age of the car would be a bad master switch or a broken wire where the door hinge flexes as you open/close the door. if there is an evidence of an east side impact by the right front door, there might be a broken wire. try operating the p/w with a direct power and ground supply to eliminate the possibility the motors went out
    or yung motor ang sira o stuck up na...
Corolla GLi 94 power windows problem
