Results 1 to 5 of 5
- Aug 2010
- 38
May 15th, 2013 06:52 PM #1i just replaced my clutch assembly (disk/plate/release bearing) and done regular change oil last weekend but eventually i got engine check error P0113 and P0135 which indicates air temperature sensor voltage is too high and error on heater sensor. I tried to reset the engine check error by removing the terminals of the battery then drained it for 20minutes. But I still get engine check error indicator. My engine become and warmer than the usual. help pls!
Thanks and cheers!
villhen
- Mar 2009
- 184
May 15th, 2013 07:02 PM #2What's your car? I would check the connections to the sensors first, and go from there. If it persists, I would ask the mechanic how he did the job. Sometimes, sensors can be sprayed with electronic contact cleaners, but if doesn't work, you need to replace them. I would be wary of the mechanic who touched your car though having brought in a perfectly working car, and driving out with some kind of problem.
- Aug 2010
- 38
May 16th, 2013 12:06 PM #3Honda City IDSI 2004 Manual yung car ko. Baka may idea kayo sa engine check codes.
Eto yung lumabas sakin:
P0113 - Intake Air Temperature Circuit High Input
P0135 - Oxygen O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)
May 20th, 2013 05:19 PM #4
- Jul 2010
- 570
May 22nd, 2013 09:35 AM #5Tanungin mo yun mechanic anong mga sensor connector nabunot niya nun magbaba siya ng transmission? Meron lang siyang hindi naibalik. Hindi mag sinungaling ang ecu.
Tentative price increase from removal of the pickup tax exemption leaked:
Toyota Hilux (9th Gen)
