Results 1 to 3 of 3
- Aug 2011
- 7
August 26th, 2011 11:06 AM #1Help guys! Nasira central lock ng Camry 2005 ko. To replace the ECU, it will cost me P21,400!
Sobra naman! Where can I find a good replacement ? Sabi nila, mas ok daw yung US made and not
Taiwan made na central lock pero about P10 T din. Suggestions, please !
- Apr 2010
- 46
September 1st, 2011 11:16 AM #2ha!!bakit need i replace ecu kung central lock lang ang problema..sa mga nagawa ko pag sira na ang central lock pinadadala ko na lang mga sa nag iinstal ng mga alarm..nag papalagay na lang ng separate central lock,cut off na yung orig niya ..cost mga 3k to 4k na good central lock module na....
- Jan 2010
- 283
September 5th, 2011 03:19 PM #3
the lock control module hardly ever breaks unless it had been submerged in water, mechanically damaged, or subjected to voltages not intended to it. try looking into the worn out master switch. usually, this switch can be disassembled and the contacts cleaned of the pitted terminals
Just a moment... just checked my vin. mine not affected. i read somewhere 2018-2019...
Suzuki JIMNY [merged threads]
