Results 1 to 9 of 9
    Apr 2011
    Problem 1: gauge light
    maliwanag naman siya pag kakabukas lang ng kotse,,pero pag tumakbo na..medyo nag didim na siya..hindi naman nag fflicker.. ano kaya problem?
    Problem 2: power antenna
    hindi siya tumutuloy pag direcho start na engine..ang technique ko is buksan ko muna yun kuryente ng kotse (half click lang) then siyaka ko bubuksan radio then tuloy tuloy na yun angat ng antenna and consistent siya pag ganun yun style.ganun din pag bababa ko antenna same procedure. fuse ba ito? may separate fuse ba ang power antenna?
    TIA
    Feb 2009
    Quote Originally Posted by sn0wbLind View Post
    TIA
    sounds like you have bad grounding at the 200 zone (behind the dashboard). what is your make, model, year, mileage and last thing done to the car?
    Apr 2011
    sentra series 3.
    kelangan baklasin ang dashboard?
    Apr 2011
    btw, whats a 200 zone?
    Feb 2009
    the area behind the firewall on the passenger compartment side behind the dashboard
    Apr 2011
    anung pwedeng solution sir? akala ko power antenna na yun mismong sira.
    Feb 2009
    locate the ground wires, clean surface contacts and re attach snug tight. as for the power antenna, we used to spray wd40 on the antenna rod itself and run it up and down until the whole rod is lubricated. this process prolongs the life of the plastic geared strip drive and the plastic clutch drive of your pwr antenna
    Apr 2011
    baklasin ko yun panel gauge then make sure na they are properly connected yun mga wires sa likod nun? dalhin ko na lang siya sa magaling na electrician para sure. hehe.. thanks sir!
    Jul 2010
    Possible marumi contact ng Battery terminal. Need to install grounding kit kung luma kotse. Linisan na rin yun contact ng Ignition Switch. Check battery voltage kung umaabot ng +13.5V pag umaandar ang makina.
dimming gauge lights;power antenna problem
