Results 1 to 4 of 4
- May 2005
- 20
May 24th, 2005 05:48 PM #1Guys help naman.
i have a 94 lancer el.
anyway, after work, started the car to go home, pero ayaw mag start, parang mahina yung battery. so tulak namin para mag start. pag uwi, passed by a battery shop, pa check ko, ok naman daw yung alternator it's charging ok, so palit ako ng battery. ok naman for a few days, even had a long trip last weekend to batangas, monday morning ok naman 1 click ang start, then nung uuwi na ako, ayaw na mag start, patay yung battery, pero after a while, nag on yung clock saka yung mga warning lights (pero mahina), tapos ayaw pa ring mag start. so tulak ulit kami, after i got home off ko, then start ulit, ayun ayan na mag start. you guys think alternator ang problem?
May 24th, 2005 08:35 PM #2
pa check mo sa auto electrician, kung nagchacharge ang aleternator or baka meron kang grounded.
May 24th, 2005 08:41 PM #3
pwede mo i check yung alternator mo kung ok pa, tap a screwdriver to the alternator with the ignition on, dapat magnetized yung alternator
the impression i got, is that carx apparently is familiar with the exact m.o. of the "seller"...
2022 Toyota Fortuner
