Results 1 to 4 of 4
    May 2005
    Guys help naman.
    i have a 94 lancer el.
    anyway, after work, started the car to go home, pero ayaw mag start, parang mahina yung battery. so tulak namin para mag start. pag uwi, passed by a battery shop, pa check ko, ok naman daw yung alternator it's charging ok, so palit ako ng battery. ok naman for a few days, even had a long trip last weekend to batangas, monday morning ok naman 1 click ang start, then nung uuwi na ako, ayaw na mag start, patay yung battery, pero after a while, nag on yung clock saka yung mga warning lights (pero mahina), tapos ayaw pa ring mag start. so tulak ulit kami, after i got home off ko, then start ulit, ayun ayan na mag start. you guys think alternator ang problem?
    pa check mo sa auto electrician, kung nagchacharge ang aleternator or baka meron kang grounded.
    pwede mo i check yung alternator mo kung ok pa, tap a screwdriver to the alternator with the ignition on, dapat magnetized yung alternator
    Jan 2003
    ndi kaya maluwag yung ground (neg) ng battery mo?
Alternator problem?
