does your car batteries lasts or exceeds their warranties? nowadays parang seldom na yung lalampas sa warranry period. either it will start to fail or conk out totally bago maabot or just after the warranty period. nasubukan ko na magpapalit sa motolite for free at di pa naabot warranty, glad i kept the receipt.
when we used the cheap champion by motolite,
in everyday manila traffic, when i used to shut down the engine during long traffic stops, it died on its 13th month. it had a 12 month warranty. sigh.
in contrast, my son, driving a near-identical innova as mine, but regularly driving long highway drives, his champion battery lasted 4 years.
only once in my driving life, did my battery die within the warranty period and (successfully) claim warranty.
i am confident, the big majority of motolite users have their battery die after the warranty.
otherwise, motolite would be out of business.
This thread seems to have made a weird turn. What started off as a discussion about LiFePO4 (LFP) batteries (and probably other car battery chemistries) devolved into just another lead-acid battery thread. :D
Anybody actually using LFP starter batteries in their car? My Amaron is near EoL at 5 years and I'm looking at either an LFP solution or go back to Amaron.
Sorry to split hairs but, LiFePO4 (LFP) ≠ Li-Ion.
It seems that LFPs have a wider operating temp than lead-acid batteries. But I see your point. As with any batteries, an increase in temp corresponds to a decrease in expected life. But then, LFPs are rated for thousands of charge cycles compared to lead-acid's hundreds. So even with non-ideal temps, I think LFPs would still come out on top in terms of performance and longevity.
Col. Harland David Sanders got Motolite's back.[emoji16]
Sent from my SM-S901E using Tsikot Forums mobile app
Agree on the two batteries' relationship. I would call them Lithium-based rechargeable batteries in general. I just felt the need to refer to them in exact terms, IMO... LFP vs Li-Ion. There are "Li-Ion" cells and there are "LiFePO4" cells. They have vastly different characteristics, not the least of which is nominal voltage, energy density, cycle life, etc. Having that distinction removes any confusion on what specific battery chemistry is being discussed. That's why I meant by splitting hairs. ;)
For the same reason, I wouldn't use Li-Ion cells inside a hot engine bay due to their explosive nature. LFP cells on the other hand, should fare significantly better under the same conditions.
Curious also how those ReadyGo LFP packs are doing.
In my neckodawoods, there's 1 outside their regional HQ....serving the neighborhood their fingalickin' good original & upset-stomach-inducing spicy fried birds 24/7.[emoji4]
but that's not accurate and that nomenclature isn't adopted by the industry.
in front of me right now are a bunch of A123 ANR26650M1B cells. they're lifepo4 in metal can format 26650. they're lithium ion cells, it says so right there on the title
also got a bunch of panasonic NCR18650. "ncr" is panasonic's name for "NCA" chemistry used in tesla model S. can be discharged down to 2.5v. also a lithium ion
got 102 cells in 17s6p pack made from samsung 26F cells. "NMC" chemistry. cutoff is 2.75v instead of 2.5v on the NCA. again, lithium ion
3 different chemistries, 3 different characteristics and voltages. all are lithium ion. the industry refers to them as lifepo4, nca, and nmc. btw there are other chemistries out there outside of these 3 common ones. then there's sodium, etc
btw i graph battery discharge curves for fun
The excerpt you put up clearly states it's an LFP. Anyway, you are correct naman and you made your point. But say, if I search for "Li-Ion", I'm shown cells with a nominal voltage of 3.7V. If I look for "LiFePO4" instead, I end up getting results for 3.2V cells. So again, to me at least, it's not helpful to refer to LFP cells (and other lithium variants for that matter) by their generic "Li-Ion" catchphrase because they all have very different characteristics.
FWIW:
Would I leave a "Li-Ion" battery inside my car, engine bay, or trunk? I most certainly will NOT.
Would I leave a "LiFePO4" battery inside my car, engine bay, or trunk? Sure!
That's the kind of distinction I was trying to convey.
ayun na nga bro, AT kasi kaya medyo alangan ako.
kaso madami pa nasa lazada cart ko [emoji1787][emoji1787]
Sent from my SM-A736B using Tsikot Forums mobile app
nagkasya sa gen 1 vios? [emoji38][emoji38]
oo nga, buti kumasya at hindi tumama sa hood.. laki nun 3sm.. for gas engine, malakas pa yan 300cca.. hehe
sa diesel medyo delikado na yan..
