Results 11 to 20 of 43
October 20th, 2023 05:34 PM #12
ilan years tumagal bro?
Sent from my SM-A736B using Tsikot Forums mobile app
October 20th, 2023 07:21 PM #13
ah so under pala sa motolite umbrella ang mega force. i suppose they're cheaper than those sold under the motolite brand. mukhang long life din pala as the previous poster mentioned
iyong outlast battery corp buhay pa ba? iyan dati ang preference ko kasi gusto ko iyong light blue w/ red highlights color scheme ng casings nila.but then i changed to motolite kasi nagkaroon ako ng bad experience w/ them. tapos eventually naging suki ng amaron
- Feb 2014
- 2,715
October 20th, 2023 07:37 PM #14currently using a megaforce and amaron. both started out 620cca (what a coincidence!)
megaforce now 1yo, cca is down to 555
amaron almost 1yo, cca still at 615
so megaforce is the same motolite cr*p just w/ cheaper manufacturing costs abroad
October 20th, 2023 08:35 PM #15
battery life expectancy or service life is subjective. factors affecting the life of your cars' battery are:
1. vibrations and shocks. if the battery hold down is not there or not doing its job. the battey plates shake off the lead compounds and settle at the bottom of the case up to the time it causes short circuits betweenthe plates( wet cell lead acid type except gel types)
2. start/shut down cycle duratio
3. ambient temperatures
4. amount of parasitic load(electunilc tuned radio, anti theft systems. computer memory, electronic clock, computer keep alive memory (KAM)
5. charging rate of the system
6. size of battery in CCA, CA, AH rating
7. age of battery at the time of purchase
8. alternator belt condition(except hybrids and electric cars)
9. condition and resistance of the battery terminals
10,condition of the alternator brushes(designed for 5 years or 100k km).
11. quality or purity of the electrolyte
12. quality of materials used in manufacturilng.
so, it is very subjective to say the least how long your battery is going to serve youLast edited by jick.cejoco; October 20th, 2023 at 08:38 PM.
October 20th, 2023 10:13 PM #16
Unlike starter lead-acid batteries which are inherently designed for max current delivery, there's a lot more failure points in an LFP pack... the quality and performance of the LFP cells themselves, the quality of the BMS, the quality of the internal wiring/bus connections, etc. Anything wrong in any of those areas could mean a drastically shorter lifespan or even cause a safety concern.
Though highly unscientific, I am toying with a few LFP 12V packs in UPSs that were designed to use lead-acid 12V 9Ah batteries. They will undoubtedly not be fully charged owing to the fact that the charging algorithm is different. But 2 out of 3 have the UPS energized 24x7 (charger is active) while the 3rd one is turned on about 3-4 times a week. I'm curious what the lifespan would be for each.
October 20th, 2023 11:54 PM #17
October 21st, 2023 04:46 PM #18
budget version ng outlast is powelast DAW as per batt dealership i spoke with (amaron suki)
btw unsure if i should replace mine, 356cca nalang daw (2sm) and install date is 2021 DAW
di naman palagi hard starting, so iniisip ko palitan by end of year
OR avoid the risk of tirik and get amaron 2sm at 4.6k (discounted na battery trade in)
- Jun 2005
- 3,774
October 21st, 2023 08:44 PM #19Same tayo. 356cca na lang din yung 3SM battery na nakalagay sa vios gen1 ko. Hehehe.
Sa innova yun talaga..mahina na cranking for diesel pero mukhang malakas naman for gas kaya pinapalit ko muna. Once a week lang naman ginagamit yung kotse eh. Hehe
Sent from my 2107113SG using Tsikot Forums mobile app
- Feb 2014
- 2,715
October 21st, 2023 10:17 PM #20
5yo din44 stock battery on the ecosport. 220cca nalang but still started w/o hesitation. at that point pinalitan ko na.
your 356cca probably has some life left in it
btw i wasn't afraid to drive around w/ such a weak ageing batt coz it's an m/t and i have a jump-start powerbank
A little ot: I disputed several charges credited to me a month ago and mptc finally corrected ...
cavitex easydrive error
